It will spin and drain but will not agitate - Washing Machines
  • Washing Mach... Master
  • 909 Answers
Very possible the motor is faulty. There are three sets of windings on these motors, Forward wash, reverse wash, and spin. If motor checks out ok, then the timer is faulty.(normally it is the motor).
Posted on Aug 04, 2010
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Have a circa 1999 Kenmore Three-speed clothes washer (Top Loader) that keeps on agitating regardless of the cycle I put it in. Some cycles do nothing at all, but others (such as Rinse) make it just keep...
The clutch assembly works only to release the basket allowing it to spin during the drain and spin cycles. The drain function works only when the spin function works. If the machine also agitates during spin cycles, then the problem is in the transmission assembly not able to release the agitate gear from the agitate spline in the drive shaft.
Sep 30, 2010 | Kenmore Washing Machines
Agitator doesn't agitate. Fills, spins and drains
Unfortunately, that sounds like a transmission issue. Power is getting to the trans, or it wouldn't spin, but the other part of the trans that causes agitation is broken.
Nov 15, 2009 | Washing Machines
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Wont drain or spindry-model 110.13212200 topload
To check the lid switch set it on spin. Should spin with lid closed & not spin with lid open. What is your problem ? (not filling ) ( not agitating ) ( not draining) ( not spinning ) it won't have an exit filter.
If the lid switch is ok it should agitate drain & spin .. The lid switch could stop agitate on some & not on others. If it is not draining it could be the pump. Sometimes a sock or something small can go down the drain and get in the pump & stop it up then it won't drain
like it should. Always say what the problem is like agitate or spin.
Hope this helps
Feb 02, 2018 | Kenmore 24432 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
