Question about Health & Beauty
My lg gd150 suddenly switches of automatically what can i do to solve this problem.
DON'T CAN DETECT MEMORY CARD
Posted on Feb 18, 2011
Power lift gate will not operate
You have to pull the inside door panel off an check it out , only way !
  • The lift gate latch release is inoperative/does not operate correctly
  • Circuitry
  • Liftgate release switch (integral to the liftgate release handle)
  • Liftgate release motor (integral to the liftgate latch)
  • Power liftgate module
  • SJB
  • Go To Pinpoint Test F .
Normal Operation The smart junction box (SJB) does not release the liftgate unless the doors have been unlocked electronically or the request is initiated from a remote keyless entry (RKE) transmitter.
The SJB sends a voltage signal to the liftgate release switch (part of the liftgate release handle) through circuit CPL45 (BN). When the switch is activated (the handle is pulled), the signal is routed to ground through circuit GD150 (BK/WH). When the SJB detects a request from the liftgate release switch, the SJB provides voltage through circuit CPL10 (BN/BU) to the liftgate latch release motor (integral to the liftgate latch) (vehicles with a manual liftgate) or the power liftgate module (vehicles equipped with a power liftgate). For vehicles with a manual liftgate, ground for the liftgate latch is provided through circuit GD150 (BK/WH).
DTC B2666 - is an on-demand DTC that sets when the SJB detects a short to ground from the liftgate release switch input circuit.
DTC B273A - is an on-demand DTC that sets when the SJB detects a short to ground from the liftgate latch release output circuit.
DTC B273B - is an on-demand DTC that sets when the SJB detects an open or short to voltage from the liftgate latch release output circuit.
    Possible Causes
  • Circuit CPL45 (BN) open or short to ground
  • Circuit CPL10 (GN/WH) open, short to ground or voltage
  • Circuit GD150 (BK/WH) open
  • SJB
Your best bet is to take it to the dealer !
Nov 04, 2015 | 2008 Ford Expedition Eddie
Rear wiper stopped
Do you know how to use a volt meter ? Need to check for voltage at the motor ! , need a wiring diagram. Most of the time other people on here will tell you to check the fuse's , that doesn't end up being the cause ! Most of the time it's the motor or a wiring problem ! I have seen the wire in side the rubber boot ,when you open the rear hatch break causing a no power situation to the motor . If you open the rear hatch ,door ,lift gate , what ever you call it . If you look when it is open there is a rubber boot connecting the body to the door , there are wires in side . There have been known to break ! This next part is a FORD pinpoint test. This is how ford says how to check !
PINPOINT TEST B: THE WIPERS ARE INOPERATIVE - REAR WINDOW Test Step Result / Action to Take B1 CHECK CIRCUITS CBP43 (GY) AND SBP19 (BU/RD) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Rear Wiper Motor C476.
  • Key in ON position.
  • Measure the voltage between rear wiper motor C476-3, circuit CBP43 (GY), harness side and ground; and between rear wiper motor C476-4, circuit SBP19 (BU/RD), harness side and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to B2 .
No
VERIFY SJB fuse 43 (5A) and fuse 19 (25A) are OK. If OK, REPAIR the circuit(s) in question. TEST the system for normal operation. B2 CHECK CIRCUIT GD150 (BK/WH) FOR OPEN
  • Measure the resistance between rear wiper C476-1, circuit GD150 (BK/WH), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to B3 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. B3 CHECK THE MULTI-FUNCTION SWITCH
  • Disconnect: Multi-function Switch C202.
  • Carry out the multi-function switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Did the multi-function switch pass the component test?
Yes
GO to B4 .
No
INSTALL a new multi-function switch. REFER to Section 211-05 .
Mar 14, 2015 | 2010 Ford Expedition EL
Split ac of "LG " will run in normal condition for 3 to 4 hours but when the i switch off the unit ELCB will suddenly tripped, i have checked the pressure and current drawn by the unit it found normal,...
hi there this problem is normally caused bye a bad or should i say dry joint in your DB board check that especially your neutral wire isnt loose
Mar 05, 2014 | Haier Heating & Cooling
I used to connect to the net via PC using my LG ke970 as modem. But, suddenly it stopped working one day. Says error 777 on the PC. Modem is out of order. But,this problem is only with Windows 7. Why? How...
I used to connect to the net via PC using my LG GX 300 as modem.
But, suddenly it stopped working one day. Says error 777 on the PC (windows XP). Modem is out of order. And also LG PC suite cannot run. Why? How can i solve this?
Feb 11, 2011 | LG Shine KE970 Cellular Phone
I bought a phone from crazy johns a few months ago, and my mum wants me to switch to optus, so she calls up optus and they send me a new sim card. i have a LG gd150 and whenever i insert the new simcard...
You need to contact the network you were on before optus and ask them for the "Unlocking Code" for your new phone.
They will also need the IMEI of the phone so they can look it up. if you type *#06# into the phone it should bring up a 15 digit code and that is the IMEI.
Regards, Dan
Jan 14, 2011 | Cell Phones
We have LG FULLY AUTOMATIC WASHING MACHINE MODEL NO. 8018LS 7.0 kg PURCHASED 4-5 YEARS BACK. SUDDENLY TODAY WE GOT SOME PROBLEM IN WASHING MACHINE AS "dE" written on the top of the screen. please...
Door switch fault, either replace door switch required or maybe an adjustment of the switch. Push against door inwards when displaying dE and hold pushed in to see if it goes away to confirm switch problem
Aug 29, 2010 | LG Washing Machines
How can i solve the problem of low usage of battery packup?
Friend, since it appears that way eventhough the batt is new. As a mobile phone technician i diagnose base from my experience that the problem of your phone is not the battery but the power supply I.C. called CCONT. It is needed to be replaced or resolder especialy if it is shorted.You need mobile technicians to solve this problem. good luck
Apr 29, 2009 | Nokia N70 Cellular Phone
Lg kg300 automatically switches off & on
Your handset needs to have a Software Update.
Take your handset to the authorised service centre of LG and get its Software Updated.
This will solve your problem.
Apr 08, 2009 | LG KG300 Cellular Phone
Cannot call out or recevie calls on my vx3100, fully charged and strong signal
the firmware might have got corrupted this might of happened due to virus attack or due to sudden removal of the battery when the phone is on or due to sudden switch off of the phone when the battery charge was low ...
this firmware problem can be solved by giving the restore factory settings(reset) ...
after this your problems will be solved ....
if the same problem persists then you must take your cell to flashing .....(there is a less chance to do this , 99% sure your problem will be solved in the previous step only )
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 09, 2008 | LG Cell Phones
Health & Beauty Logo
32 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
