Question about RCA Televison & Video
I have an RCA P46733AT projection TV. The tv will not power up. If you hold the power button, the light comes on but it just clicks and goes back off. There is no picture.
  • tommyboy63 Aug 04, 2010
    isn`t there a powerblock or something along that line that stores the power or something?
  • tommyboy63 Aug 05, 2010
    Thanks For all your help! I guess I`ll take it to the shop. I`m not an electronics guy. Thanks again!
  • RCA Master
  • 11,800 Answers
When you are pressing the button longer than usual the security systems in the power source are momentarily disabled and the source is forcefully started. Unfortunately it immediately detects that there's some massive short on it output lines and the secondary safety disconnects the main power (the click you hear).
Th damage must be extensive to observe this behaviour. To find and fix it the tv must be tested ; start with the power source and test the 125Volts line first (it's the main consumer and the most likely cause for the failure). If the line is dead then the High Tension module has failed - check the power transistors, the deflection diodes and the flyback transformer.
All this requires a good experience in electronics. If you don't have it then it will be better to call a repairman, and it will be expensive.
Posted on Aug 04, 2010
  • 10,515 Answers
On these RCA projection TVs there are many things that can cause your issue, bad connections or shorted components, doesn't sound simple I work on these and end up sending the chassis out sometimes to our shop to be rebuilt on the bench.
Most likely a repairman will charge at least $250-$650 to fix it, depending on if the chassis needs to be shipped out to be rebuilt.
If you want to repair it yourself, know how to use multimeter and soldering iron, could keep all precautions could read schematics, revert and i would be able to provide you some pointers.
Good Luck!!
Thanks!!
  • taran_2005
    taran_2005 Aug 04, 2010
    Thanks for your response!!
    I wish i could have a better solution. There could be a concern with power supply unit, But, you need to open the unit and you need to follow the schematics that which IC's you need to check or which fuse might needs repair.
    I know it's frustrating, however, its better to be honest.
    Good Luck!!
    Thanks!!
I HAVE A 52' RCA HDTV THAT WILL NOT TURN ON ,AT TIMES IT SEEMS LIKE IT WILL TURN ON BUT THEN GOES BACK OFF,CAN ANY ONE TELL ME WHAT THIS PROBLEM CAN BE
sounds like the power caps CP150 CP120 and CP114 on the deflection board. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit also comes with instructions.
Mar 15, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA 52" Projection TV works when it wants to.
Tries tv unplug,replug it back tv like about an hour later,tv will temp.work for that day,until tv really cold and cool down problems,probally will come back.Tv have faulty DM power supply board like dying or coldsoldering in parts like capacitors.Dying capacitors parts are leaking alway visaully have bulging up on it tops or puffing up on it tops.U have tools like a soldering iron,a roll of solders and also basic understanding of electronic?Yes.Tries to repairing tv ur self,yes tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a repair components capacitors part kits they put together u can replaced by ur self.Can't do this hire a tv shop to do it $200-300 for parts and labors.
Feb 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P4677OCK
I have P46733AT with the same problem. I ordered schematic and now looking for flyback + high voltage transistor.
When I finished I let you know what's going on.
Goga.
Jul 19, 2008 | RCA P46921 46" Rear Projection Television
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Rca tv p52771at problems
Mine did the same thing it ended up being the splitter. About 200 bucks. And then a year later it did it again. Another 200 bucks.
Nov 04, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
