Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
    Brigadier General:
  • 6,966 Answers
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 26, 2008
Panasonic f61 output
If what you identify as the output IC has failed, one or more speakers would be affected.
Nov 23, 2013 | Panasonic sa-ht930 Home Theater Audio...
MY PANASONIC SA-HT75 KEEPS ON CLICKING OFF WHEN I SWITH IT ON.WON'T START UP
There Panasonic SA-ht75 dvd Decreasing the opening treading on what's happening back immediately shuts down
Sep 05, 2011 | Panasonic SC-HT75 System
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
While i turn on my home cinema the screen is showing F61 and automatically turn it self off
The F61 message is the Panasonic equivalent to "protect". See the link below for an explanation of protect mode. Specific to your system, there is an amplifier IC that has likely failed. Depending upon the model, this IC can cost between $75 and $100. Please post the model and I'll provide the part number and cost.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 15, 2010 | Panasonic Home Theater System System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
Panasonic SA-HT 955 Home Theatre System
The F61 is the shorthand for protect mode. This indicates a problem with the output amplifier section. I don't have a listing for your specific model, but a similar one HT95 lists IC501 as the output amp chip. Check for the marking on the large black IC attached to the heatsink it may be RSN311W. If so, this can be ordered using part number: RSN311W64D-P for $95.20 from tritronicsinc.com.
Hope this helps,
Dan
Aug 28, 2008 | Panasonic Home Theater System System
Televison & Video Logo
1,507 people viewed this question
Top Televison & Video Experts
