Question about Bosch Classixx WFL 2066 Front Load Washer
I have a bosch 300 series front load washer that wont spine it fills and drains fine belt is on what could it be
  • 909 Answers
If it doesnt wash either, the brushes will possibly be the problem. You need to remove them and check the length.
Posted on Aug 04, 2010
Washer Drum Not Moving- belt is fine
Brand new belt and no other symptoms; my bet is the motor brushes. You will have to remove the motor to check this. there are 2 holders for the spring-loaded brush. I am guessing they are worn down and just stopped touching. It's a "silent failure" with no real symptoms except is doesn't move.
May 26, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
E04 error code, washer wont drain, water left in tub on a Bosch Nexxt 300 series
http://applianceguru.com/attachment.php?id=2463
Make sure you click helped, if helped that is.
Apr 12, 2013 | Bosch Washing Machines
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer wont spin belt is on pump is free of debris
Possible that the main motor is jammed or does not get power from the program controller unit. It is important that you measure the voltage at the motor when the program is set to start after the inlet valve fills water. If there is no voltage then the program controller unit is faulty.
Click this link for support : washing machine tips
Jun 25, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
My front loader fills with water, pumps and drains fine but the drum never moves or spins . Already cleaned pump, Checked belt and motor, belt is good and motor and drum spin freely.
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
May 21, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer will wash but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
200 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
