Question about Whirlpool Duet GHW9150P Front Load Washer
Error #F11.....and have no instruction/manual...how to get one?
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%#^
Posted on Sep 29, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 error code
    I appreciate the post, dan moore!
    From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
    Dec 14, 2014 | Frigidaire Kitchen Ranges
    Error code F11
    Not sure what machine you have?
    F11 Error Code for Whirlpool Duet & Duet HT :
    F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
    Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
    This is the only F11 Error code I could find for a washer.
    Jan 13, 2010 | Dryers
    I have a G1220SC model. F11 shows on the panel,
    F11 is a drain error.
    Water outlet restricted.
    ** Check for kink in the drain hose.
    ** Clean the filter combination. (p.41)
    ** Clean the non-return valve (check valve) (p. 53)
    ** Check/clean the drain
    Unplug the machine.
    Disconnectthe drain where it enters the S bend from the sink. You may find thenozzle into the S bend is blocked. Probe it with a screwdriver andclear the blockage.
    Plug in2_bing.gif the machine and re-try.
    THIS MANUAL
    may not be for your model - however it will give instructions on some of the steps above.
    If all checks out - the pump will need replacement.
    Dec 25, 2009 | Miele Dishwashers
    Drain filter F11
    Unplug the machine.
    THIS MANUAL
    Jul 07, 2009 | Miele Dishwashers
    Display will not stay on. Displays error 16.
    Before you try to change the battery:
    Paste this link into your browser and download manual:
    http://www.polar.fi/en/support/downloads?product=&category=User+manuals&documenttitle=User+Manual+for+F11+in+English+9%2F2007-&document=/gip/PKBStoGIP.nsf/web_cat/C225742500419A8AC225732F0049BE55
    This manual helped a lot to other Polar users.
    Do not forget to rate, please.
    Mar 23, 2009 | Polar F11 Heart Rate Monitor
    WHAT DOSE F 11 MEAN AND HOW CAN I GET USER MANUAL
    "F11" is a Serial Communications error. In a nut shell, the Central Control Unit (CCU) isn't communicating properly with one or more components. The following link explains:
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    This problem can be attributed to wiring, a bad connector plug, or the CCU itself has failed. You can attempt to reset the CCU by unplugging the washer for at least 30 minutes. Sometimes these error codes are erroneous and a reset will correct momentary glitches. If the error code reappears following a reset, you have a problem. Please read through the link provided. If you still require assistance, please let me know.
    If you're looking for technical data about the error code, there is a tech sheet affixed to the interior cabinet wall behind the lower panel under the door. There are three torx screws under the front edge of the panel that you will need to remove. With the screws removed, the panel will drop down then off.
    If you are looking for a User's Manual that explains the operation of the washer, you can go to Managemyhome.com and register (this is a FREE service). Once registered, look under the "Home Managers" heading and click on the "Owner's Manuals" link. Follow the instructions on the next page and your owner's manual will be available in a downloadable .pdf format.
    If you require additional assistance, please let me know. I hope this helps you.
    Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F11 error
    "F11" is a Serial Communications error. Before assuming you have a problem with your washer, the manufacturer recommends unplugging the appliance for at least 30 minutes to reset the computer. In many cases this is all that is required to correct momentary computer glitches. If you try this and the problem persists, the following link explains the "F11" error in more detail:
    In most cases this error turns out to be a failure of the Central Control Unit (CCU). If the Motor Control Unit (MCU) fails, there is usually an additional error code that will appear. I say "usually", but not always. I hope you find this information helpful. If you require additional assistance (i.e., parts, instructions, etc.) please let me know.
    Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    23 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
