Question about LG Neon GT365 Cell Phone
My LG Neon screen just stopped working! :( It works fine, the keyboard and bottom buttons and I can recieve calls, but the screen won't turn on at all. :( Helppp?
    President:
  • 1,099 Answers
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Good luck........
Posted on Aug 04, 2010
Hgfhjhfhfv
jhjnbnvg
Posted on Nov 12, 2012
I had my goggle phone slighttly wet in the rain--scren isn't coming on is there a solution?
Let me know.
Thanks
Posted on Aug 09, 2010
The scren on my lg neon is black wont show anything
call ur wireless provider and get tech support explain whats happening they'll get u a soulution or a refurbished lg neon
Feb 12, 2010 | LG Neon GT365 Cell Phone
Logitech wireless rf keyboard and mouse quit
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
regards.
Jan 28, 2010 | Logitech Wireless Access Duo Optical...
Can recieve but not send text messages it says sending failed lg neon worked fine then just stopped
okay this hapened to me what you do is go to you message menu go to message settings and go to text message then you have to go to message center number make sure the number matches the one given to you in your user manual
Jan 09, 2010 | LG Neon GT365 Cell Phone
My LG Neon got wet is now really messed up
I had the same problem and fixed it rather easily, the problem is that the componants are wet and need to be dried, if you send it away your warrenty will be flaud as it is wet and all they will do to fix it is pull it apart and put it in a drying machine so i advise you to wrap it in a towel and place it somewhere warm like a hot water cubboard or directly in the sun, it needs to completly dry. you could try wrapping it in a towel and use a hairdryer on a low setting to dry out the componants, remeber to stop and let it air evey now and then or you will get condensation on your screen, hope this helps
Dec 22, 2009 | LG Neon GT365 Cell Phone
Keyboard and mouse not working
Make sure you have fresh batteries...usually this is how to set up a wireless keyboard and mouse. Insert the reciever in the USB and hit the link button normally located as a recessed button on the bottom, a light will blink....On the keyboard press the button as before located as a recessed button on the bottom. Once linked the reciever light should stop blinking...do the same with the mouse.
Jul 13, 2009 | Micro Innovations Wireless...
Black screen on LG Neon phone
is the phone turning off because my lg neon turns off at random times
May 31, 2009 | LG RUMOR Cellular Phone
Logitech ex110 keyboard stopped working all of a sudden. unable to connect. the mouse still works fine. checked the batteries, they are ok.
First make sure the receiver is plugged into the computer. Second make sure you have fresh batteries in the keyboard and they are installed in the correct orientation. Then try the following:
1. Press the Connect button on the receiver. The receiver's LEDs will go into a sequential flashing to indicate that the receiver is ready to accept a connection.
2. Press the Connect button on the bottom of the keyboard. The receiver's LEDs will now stop flashing sequentially. Then all the LEDs go off briefly, then they will all flash once before returning to the state it was in before the connect button was pressed.
3. Your keyboard should now be connected to the receiver.
This article should also be of help:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=8121
Please let me know if this works and rate my response.
Thanks.
Apr 15, 2008 | Logitech Cordless Desktop EX110
LG Neon GT365  Cell Phone Logo
1,889 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
