Program of matrix multiplication - Computers & Internet
    Brigadier General:
  • 10,406 Answers
In FORTRAN:
PROGRAM MATMULT
PARAMETER (N=3)
DIMENSION X(N,N), Y(N,N), Z(N,N)
DOUBLE PRECISION SUM
READ, X
READ, Y
DO 200 J=1, N
DO 100 K=1, N
SUM = 0.0
DO 50 L=1, N
SUM = SUM + X(J,L) * Y(L,K)
50 CONTINUE
Z(J,K) = SUM
100 CONTINUE
200 CONTINUE
WRITE, Z
END
Posted on Aug 04, 2010
How to do matrix problems in fx991ms
The following was written for the Casio FX-991 ES. If matrix calculations are available on your calculator you will perform them as described below. ( I have no time to verify that the FX-991ms can perform matrix calculations).
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matricies, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB
To subtract MatA-MatB
To multiply MatAxMatB
To raise a matrixe to a power 2 [x2], cube [x3]
To obtain inverse of MatA already defined MatA[x-1] [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match.
Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular umbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrice by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Nov 07, 2012 | Casio FX991MS Scientific Calculator
How to multiply the matrices using fx-991ms calculator
Nov 06, 2012 | Casio FX991MS Scientific Calculator
We are trying to add, subtract, multiply, and divide matrixes, but the Casio calculator that we have will allow for us to input the information into the calc. However, it will not allow for us to add,...
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end. As to division of matrices, I do not believe that this operation exits.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
[2: D A T A] enter values in a matrix
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x^-1]. The key [x^-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
May 10, 2011 | Casio FX-115ES Scientific Calculator
I'm trying to solve a matrix using your calc--I was able to follow the steps that were located on the internet, but it does not explain what you will do next. My partners and I have spent hours and we...
How to do multiplication of two matrixes in casio fx 115es
To obtain inverse of a SQUARE MatA already defined MatA[x-1]. The key [x-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Apr 24, 2011 | Casio FX-115ES Scientific Calculator
How to do matrix multiplication
Jan 09, 2011 | Casio FX-115ES Scientific Calculator
In casio fx-991ES, i am able not to get the matrix multiplication as well as inverse when i do so get math error.
Dec 18, 2010 | Casio FX-115ES Scientific Calculator
How to use matrix in the calculator
Aug 06, 2010 | Casio FX-115ES Scientific Calculator
Matrix
Apr 29, 2010 | Casio FX-115ES Scientific Calculator
How to multiply two matricies?
Mar 06, 2010 | Casio FX-115ES Scientific Calculator
Computers & Internet Logo
123 people viewed this question
Alun Cox
David Payne
David Payne
