Question about Makita 12? Metal Cutting Saw # LC1230
The stainless steel blade for the lc1230 No.A-87024 has a very limited life span re cutting. Makita no longer sells this blade. Is it due to the fact that the blade is known to be problematic
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Problem finding blade choices for Makita circular saw
OK done some more checking and I believe you are out of luck, but before giving up hope do you have a saw sharpening business in your area?? My friend says that he has sent blades to one in my area and had the center hole bored out to the appropriate arbor hole and the blades run true and from what he tells me it is relatively cheap, so check first and see and then you can buy a blade in the diameter you want and have it bored out. Sorrry I couldn't come up with anything else, I check about 6 diffferent mfrs and they all have the same.
Posted on Jan 21, 2009
rowdy45176
  • 2176 Answers
SOURCE: makita chopsaw when cutting angles blade is
Try going to Makitatools.com and typing in your model number on the right side of the page at the top. It will take you to another page where you can download an owners manual, I saw where page 6 and 7 would be helpful. Let me know if you need more help
Posted on Apr 16, 2009
1fastbob
  • 301 Answers
SOURCE: bought the makita 18 volt lithium power saw which
I have a Ridgid brand battery operated circular saw 18 Volt and it works very well for a battery operated saw. It eats 2x4's and 2x6's very well. I have noticed that when the blade only gets slightly dull it will not cut worth a darn. Keep a sharp blade on it and maybe try a different battery. A battery powered saw is NOT a replacement for a plug in saw, but they sure as heck are handy.
Cutting a 40mm worktop should be no problem unless it is a hard wood. If it is a hard wood you might need to get a plug in saw and a very good blade.
Posted on Nov 04, 2009
Testimonial: "i think it should cut worktps too just wondering if i've dud batts how would you know"
SOURCE: Makita Saw blade brake doesn't work.
i have a makita still saw put i pull cored but it dose'nt start
Posted on Jan 21, 2010
What is the role of stainless steel products?
Products which are manufactured by stainless steel is mainly depend up on the type and quality of stainless steel means it may be plain, ordinary stainless, like in a handle or pot, then any alloy steel drill will do. On the other hand, if it is hardened stainless like what is used in instruments, you probably will need carbide, although you might get a tool steel drill to make one hole.
Stainless steel is defined as a steel alloy with a minimum of 11.5 wt% chromium content. Stainless steel does not stain, corrode or rust as easily as ordinary steel, but it is not stain-proof. It is also called corrosion resistant steel when the alloy type and grade are not detailed, particularly in the aviation industry. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Common uses of stainless steel are cutlery and watch straps.
For detailed information visit at: Solutions of Stainless Steel Products
Feb 01, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
Tip
How to clean stainless steel appliances
Use extra virgin olive oil to clean and shine stainless steel. Apply with lint free cloth and rub into stainless steel following the grain of the steel. Then with dry portion of cloth buff like you would car polish and you will be amazed at the shine. It also provides some protection due to the fact it is a oil.
on Feb 02, 2015 | Kitchen Appliances - Others
How do you cut stainless steel hand rail without leaving burn marks
Stainless steel needs to be cut by a plasma cutter. The heat generating from the friction of blades will burn the metal.
Jun 04, 2010 | Saws
Bought the makita 18 volt lithium power saw which i thought would cut a 40mm worktop in fact i struggles to cut 9mm ply is this it's limit or is there something wrong with the batteries
Nov 03, 2009 | Makita BL7010 7.2V Lithium Ion Battery
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I...
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Jul 12, 2009 | Saws
Use of a Sait Cut abraise wheel to cut PVC Pipe
I worked at a tool rental business while going to college and became familiar with OSHA requirements as it pertains to construction. There is an old saying that if you follow the rule-book by the letter things will quickly come to a grinding halt. I checked on OSHA web site and could not find anything on you question. I recall that using the correct blade only results in a cleaner cut, however there is the possibility that the pvc material can load-up on the blade and cause jambing. An inspection of the blade will answer this. More important is that all safety items are in place like the blade guard and that all workers in the vicinity of the saw are wearing eye protection. We used Norton brand abrasive blades and the following is their guide. APPLICATION GUIDE:
Concrete:
For concrete/masonry - silicon carbide specification for brick, block, concrete, and other masonry materials.
Metal: For metal/steel - aluminum oxide specification for mild steel, stainless, and metal decking.
Asphalt: For use when cutting mostly asphalt.
Asphalt / Green Concrete: For asphalt and green concrete - silicon carbide in coarse grit range. For high performance, hot pressed wheels provide significantly longer life.
Ductile: For ductile iron and cast iron pipe - formulated with a special blend of silicon carbide (for cutting) and aluminum oxide (for long life). This specification is also suitable for cutting PVC.
Hope this helps, enjoy
Dec 09, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Blade type
blades are available for different applications. A few common blades include:Steel Blades are inexpensive and work well for cutting softwood. Steel blades dull quickly in hardwood. High-Speed Steel Blades are harder than steel blades and stay sharp longer. Carbide-Tipped Blades are more expensive than other blades, but they stay sharp much longer than steel or high-speed steel.
Aug 27, 2008 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Ionic pro turbo
You need to clean all the stainless steel contact points inside the unit, not just the blades. Make sure you unplug the unit before doing this.
Mar 01, 2008 | Ionic Pro TURBO Air Purifier
Makita  12? Metal Cutting Saw # LC1230 Logo
69 people viewed this question
Top Makita Saws Experts
Marvin
Marvin
ray gallant
rlev_7
Level 1 Expert
Are you a Makita Saw Expert? Answer questions, earn points and help others
