When I try to compile a module with GTK -2.0 on a Linux Fedora Core 13 machine I get following error message: gcc -g helloworld.c -o helloworld `pkg-config --cflags gtk -2.0` \ `pkg-config --libs gtk -2.0` gcc: -pthread: Bestand of map bestaat niet In English: gcc:-pthread: File or map does not exist
  • ralfmeirsman Aug 04, 2010
    Does anyone know what this -pthread stands for?
    found a solution to the problem:
    Now I use gcc helloworld.c -o helloworld `pkg-config gtk+-2.0 --cflags --libs`
    and it works fine.
    President:
  • 567 Answers
Hi there might be an error in the present installation,you should uninstall the GTK-2.0 and reinstall it again.
Posted on Aug 04, 2010
    Guru:
  • 632 Answers
You may not have defined the location of the Helloworld file location
Example Dir ADFS::HardDisc.$.Tools.!GCC.Example.CType 'Ex' to check that you have changed to the correct directory. This command gives a list of the files in the current directory. You should see 'c' in the list.
Now you're ready to compile.
  • 1 more comment
  • Simon Swales
    Simon Swales Aug 04, 2010
    Ex will display the files in current dir which its trying to compile from
    If you dont want to change it then you can just move your .C file into that directory and then re-issue your compile command and it will work.
  • Simon Swales
    Ok, Congrats and wish you all the best in future, The world is lacking many programmers and we need more people to get into coding new applications..
    You could also save alot of time and use a C compiler rather than using GCC to compile, So you also have an IDE interface and an easy way of building/debugging and correcting any problems...
    Net-beans is a great IDE for linux environments. http://www.netbeans.org/downloads/index....
  • Simon Swales
    You can also use GCC but an IDE would help a-lot in creating your own applications without writing the files manually if that is what you are currently doing..
How we use linux complier to edit, debug and compile computer programes
I'm assuming your using some form of C.To edit, you can install command-line based editors like emacs and vim, or use gui editors such as gedit or kate. There is also IDE options like EclipseTo compile is relatively simple, most linux distros come with a builtin version of gcc and g++ (the c compiler and c++ compiler); more information here: http://pages.cs.wisc.edu/~beechung/ref/gcc-intro.htmlTo debug, it is a little more complex and you may have take some time to properly learn the workings of a debugger. If you're using Eclipse, I'm pretty sure there's a builtin debugger in that which would be rather simpler to use than the alternative I use: gdb (http://www.unknownroad.com/rtfm/gdbtut/gdbtoc.html).
Oct 10, 2011 | fedora Linux Operating System
Gcc and g++ command not found in fedora 12 and iostream also working
you need to install them, with yum for example:
1. open terminal
2. get root with
su -
3. install them
yum install glibc-headers glibc-devel gcc-c++ gcc
Oct 14, 2010 | fedora Linux Operating System
I installed fedora8 linux os after installation gcc compiler is not working(c programs are not working)
Most probably not installed with your OS --check-- see if you have "cpp" or "gcc"
Aug 27, 2010 | fedora Linux Operating System
How to download and install apache on linux5
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Dec 30, 2009 | Red Hat Enterprise Linux ES 3 Standard...
Gcc and g++ not working in recently installed fedora 10
You need to install GCC, I recommend you to install It through yum,
Mar 20, 2009 | fedora Linux Operating System
Install xp vista linux
If you're trying to install all three operating systems onto the same partition it's creating a conflict, more than likely between Vista and linux. XP and Vista are similar enough and recognize each other, putting them in the same partition is ok, but try setting up another partition to install the linux to. I'm curious as to why you want or need all three on the same machine?
Jul 10, 2008 | Dell Vostro 1500 Notebook
How i can install linux on hp dv2519tu laptop.
i think the cd from which you are installing might have got scratched so the cdrom couldnt read some files which are needed for installation ... so i suggest you to try changing cd....
there is no problem with installing in laptops we can install linux in any laptops......
i suggest you to install fedora core instead of redhat...
fedora core has good functionality and it has inbuilt firewall security also for internet and it has got good options ... so try installing fedora core 5,6, or 7 .. if you dont have means you can download from net as linux is open source to all any1 can download from net ...
there are many other linux available like ubuntu,suse, mandrake etc....
suse linux is also very good it is the very user friendly linux ...
there other linux which can be run by cd only which doesnt need of installing it just like knoppix live cd etc....
be care ful while partitioning if you make mistake you will lose all datas ....
Feb 08, 2008 | Computers & Internet
Display driver problem
ya there is a problem with driver while installing fedora core 4 i think ... u must have also tried in that only ... so i suggest you to install other version of linux... there are many other versions available like ubuntu,mandrake,redhat. or you just give try with installing the latest version of fedora core ...( try fedora core 6 or 7)..
as linux is a open source for all you can download it from net for free.............
Nov 22, 2007 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Alun Cox
David Payne
David Payne
