Question about Lexmark X340n All-In-One Laser Printer
Error message 31.05 missing or defective cart. copier will not print now?
4 Suggested Answers
  • 300 Answers
SOURCE: 31 missing or defective cart.
Try changing the photoconductor kit
Posted on Jun 02, 2008
Printtech
  • 1087 Answers
SOURCE: 31.05 missing or defective cartridge message.
This may have something to do with the contact springs. Cleaning the toner contact springs with a cloth damped with a bit of alcohol will make continuity more sensitive to the toner cartridge chip. If problem persists, I strongly suggest you contact Lexmark technical support for further assistance. Thanks.
Posted on Aug 05, 2010
Printtech
  • 1087 Answers
SOURCE: am o imprimanta lexmark E340
En este art?culo se describen los pasos para solucionar problemas, por favor visite el enlace http://bit.ly/l7yPlU
Para m?s informaci?n, p?ngase en contacto con Lexmark Soporte T?cnico
Traducci?n con traductor Google
Posted on Jun 27, 2011
Lexmark 352dn 31 missing or defective cart
The 31 error message means that the printer is detecting the toner cartridge is either faulty or not installed properly. You might need to replace your toner cartridge.
Nov 12, 2012 | Lexmark E352dn Laser Printer
My printer stoppped working. It has one green light blinking When i try to print the floowing message shows up in the computer: Service error 6C00. Cancel printing and turn the printer off and then back...
Most likely the the ink carts are low or you have a one defective cart. Do steps in sequence
1. Reseat carts 2. Reset the printer. 3. Rpl carts one at a time till you find the defective one.
Feb 21, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Get error message E5 on my canon MP160 all in one printer. One day everything was fine printed perfect next day E5 message & said that it doesn't recognize the ink cartridges. Impossible it worked...
Make sure all carts are seated properly, sometimes they pop up. When you open the cover, the one with the blinking light is the problem one. It's also possible to have a defective cart. from Canon as well.
Jan 07, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Dell Photo 926 printer keeps saying that it cant align and wont print after installing new cartridges. Says tape is still on there but it isnt.
1. cancel the alignment .
2. try one cart at a time and only make a copy of a test document ...(press "select" if u get cart missing error ) ...only of the carts is causing the error
3. possible u have defect cart ..or the internal sensor could have gone bad (rare scenario )
4. get a replacement carts...
Oct 25, 2009 | Dell 962 Photo All-In-One InkJet Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
Jun 02, 2008 | Lexmark E342n Laser Printer
New cartridge
Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
May 13, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark X340n All-In-One Laser Printer Logo
1,626 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
