Question about Garden
Paslode nailer bend the nails when fired gpalic@sbcglobal.net
  • 10,865 Answers
Hello. There are a couple of reasons why this happens:
1. The air pressure is too low for the type of wood yhou are entering. Ideally you should have between 90 and 100 PSI.
2. Sometimes, depending upon the hardness and density of the wood you have to crank the pressure up even higher.
3. Also, you have to have the gun aligned so that the nails are going straight in, and not at an angle.
Finally, take a look at the pitch the nails are at when you load the gun and experiment with the angle of the gun against the wood.
I believe one or more of these corrections will solve your problem. Happy nailing. J.
Posted on Aug 04, 2010
My paslode impulse 1m50f18 fires normally but no nail apears with paslode nails?
not sure what you mean" no nail appears with paslode nails" if it fires make sure the nails are correct for your gun
Sep 08, 2015 | Air Tools & Compressors
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode compact nail. the firing pin will not return
heatman101
Oct 19, 2010 | SK Paslode Sk312 Framing Nailer O`ring...
A nail got jammed and was cleared. Now the gun won't fire.
heatman101
'l;l;
Sep 11, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
Jul 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode Impulse Framing Nailer won't operate
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
NAILER WONT FIRE NAILS
DO NOT USE WD40 . Is The Nailer fireing? If Not check the micro switch by the fan . Make sure it is pushing on the switch.. Otherwise bend it a little
Jul 06, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 5350/90S PM Powermaster Bends nails over
USUALY THIS IS CAUSED BY TO LOW OF AIR PRESSURE(NEED AT LEAST90-100PSI)OR NAILING INTO SEASONED HARD WOOD SUCH AS OAK,OR THE WRONG DEGREE PITCH OF THE COLLIATED NAILSHOPE THIS HELP'S.PLEASE RATE THIS .
May 16, 2009 | Air Tools & Compressors
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
