Question about Microsoft Xbox 360 Console
My xbox turns its self off after playing it for about 2 mins this is also the case when i try to down load.
  • 42 Answers
When it shuts off does have a red ring if so then you need to send it in to microsoft
Posted on Aug 05, 2010
Why is my Xbox 360 S freezing after 20 minutes?
This could be a case of the system over heating in which case you should have items removed from near your console.
You could also try removing the hard drive (make sure your Xbox is turned off before you remove it) and using your xbox without it, if that stops the freezing error then the problem lies in your hard drive.
(How to remove your xbox hard drive: https://www.youtube.com/watch?v=2NhALsgzR0M )
Jul 30, 2017 | The Video Game Consoles & Games
Why does it keep shutting down after 5 min of playing a game?
Xbox Keeps Turning Off - Xbox 360 S - iFixit
https://www.ifixit.com/Answers/View/.../Xbox+Keeps+Turning+Off
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Does Your Xbox 360 Keep Freezing? ' MyGamerXP
www.mygamerxp.com/xbox/does-your-xbox-360-keep-freezing/
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
My 250GB Slim keeps turning itself off every 5 - 10 minutes ...
forums.xbox.com/xbox_support/f/7/t/156970.aspx
Xbox
Jan 17, 2016 | Video Game Consoles & Games
My xbox 360 has a red ring around the power button.... how do i fix it????
If you are technically minded, this is very simple to fix, the hardest part is taking the consle apart.
there are many kits with self explanatory instruction available on the web, but try to find an all metal kit, ones with nylon washers only solve the problem in the short term.
once the case is opened, u need to remove the fan shroud and fan assembly, then remove the motherboard from the casing. turn the board upside down, and CAREFULLY!!! prise off the 2 silver x clamps from their locating lugs, the 2 processors/heatsinks can then be removed.
Clean all traces of thermal compound off the board and heatsinks using either white spirit or an alcho solution, if using w/spirit dry thoroughly.
apply new thermal compound, just enough to cover the processors on the board, and using the kit bought from ebay position the screws and washers and re-attach the heatsinks.
Now u need to plug the xbox into the mains, and attach the av cable, turn the xbox on, but dont reconnect the fans as u need the heatsinks to get hot and the console to overheat, this will take between 30 seconds to a coupe of mins, and when hot enough the console will show 2 red lights.... this is perfectly normal!!!!
once the 2 red lights appear, turn the console off by pullin the power cord out, do not use the on/off button. allow the console to cool for about half an hour. reassemble the xbox and hey presto u should now have green lights and the console fixed.
Mar 12, 2010 | Microsoft Xbox 360 Console
The two left sides of my Xbox 360 keeps lighting up and i barely
when did you buy the cooler?
the 2 red lights only appear on the left side of the turn on for your xbox when you have played for a big amount of hours on your xbox i recommend not playing the system for a day so it allows it too cool down if you have this problem if it persist contact a support manager at Microsoft
Feb 22, 2010 | Microsoft Xbox 360 Console
When I play 4x4 evo 2 on my xbox 360 it will not save or load
Rob B is totally wrong, it has nothing to do with your 360 over heating or going to have the Red Ring Of Death. I am having the same problem too. Some of the old xbox games are compatible with 360 but some have bugs that do in some case render them unable to play to optimal performance. Try switching your display settings, I have one game that won't play at all unless my display is at 480p
Feb 19, 2010 | GODGAMES 4x4 Evo 2 for Xbox
I am playing Modern Warfare 2 on my Xbox 360 and after about 20 minutes it quits reading the disk. Any clue on how to fix this? Other disks work just fine.
Check the disc for any scratches. Clean the disc with some disc repair solution. If you just purchased the game try and take it back to where you bought it for an exchange. If there is no scratches or anything that could stop the disc from reading right it could be your Xbox. Xbox has been known to have many issues with heat maybe your Xbox is getting to hot. In which case the problem is your Xbox and you will have to call Microsoft about getting a new Xbox. My Xbox started to go bad in the exact same way. I would play multiplayer for awhile and it would freeze after playing for a little while. I would then turn the xbox off for a few min then turn it back on and it would work again for awhile untill a few days later when i got the red ring of death which means a hardware fail.
Dec 26, 2009 | Video Game Consoles & Games
2 red lights
Your xbox is overheating.
1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. 3. If the two lights continue to flash after trying the above steps, you'll need to contact Xbox Customer Support.
Jul 13, 2009 | Microsoft Xbox 360 Console
2 red lights on the ring of light
your xbox 360 is overheating its called the red ring of death look it up on google you can have microsoft fix it if you still have a warranty on it, it shuts down so none of the components in the xbox 360 get damaged
May 30, 2009 | Microsoft Xbox 360 Console
Games will start up and load, but after a few min.
May be your controller, have you tried to play with a different controller?
if this problem contenues to exist, call 1800-4MY-XBOX
Dec 30, 2008 | Microsoft Xbox 360 Console
Wont load the game
Shut the system down for 10 mins. at least and unplug too.
Let the system rest and then try it
Dec 11, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
