Question about Philips GoGear SA5245/37 Digital Media Player
My Philips GoGear SA52XX mp3 player fails to connect with my computer. when i plugg it into the computer it says updating player, and then fast afterwards it just goes into music library, but nothing will show up. and when i check on computer's hardware options, and i locate the philips gogear SA52XX, it says, hardware does not start, (failure code 10) i have no idea how to solve this. i have tried everything. still it does start properly on another computer. i hope you can help me with this problem. cause hereby i really dont know what to do anymore.
SOURCE: Philips GOGEAR SA6045 MP3 Player doesnt register.
I worked on this thing (sa6045) for three hours................no luck.Finally got a fix.....Go to programs add/remove menu under control panel and delete Philips device manager.Then go to Philips site and download new driver:http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&mid=Link_Software&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20080506223817_68.47.250.64&ctn=SA6045/37&dct=PAL&did=AEN&file=/files/s/sa6045_37/sa6045_37_dmr_aen.htm
Install your new driver and be SURE windows media player is not running or trying to sync.If it is running in background philips device manager will not work.Once new driver is installed you can pull up the repair panel and do a hard reset thru software on your Sa6045.
Good Luck
Posted on May 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: when i turn on the philips gogear it says philips,gogear,updating and then it jams
This player has an issue that the latest firmware fixes, re: constant freezing during updating. If you can just get the computer to recognize the player, and load the firmware update then you should be fine. The firmware update should load when you go to the "Update" button on the latest Device Manager (the version of the Device Manager from Philips' website, not from the install CD).
If the computer is not recognizing the player, then try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Posted on Jun 10, 2008
SOURCE: Philips GoGear 2GB MP3/Video Player LOCKED ?
you have to look at the side and shift the lock button
Posted on Sep 21, 2008
SOURCE: philips gogear 8 gb mp3 player
My gogear is just froze after unplugging it. I left on charge also....but no action...When I try to switch off it doesn't get to switch off or do anything....just froze....I also want to know how to delete songs...Please help me. Thanks.
Posted on Dec 26, 2008
SOURCE: Philips GoGear SA3125/37 MP3 Player Charger cable
Anyway, if you have Motorola, you can use it charger for charging mp3 :) (My Aunt have Motorola mobile phone, and I used her charger for charging my MP3 :)) Sorry for weak English :P
Posted on Mar 13, 2009
It cant be read by computer
it cant be read by my computer my philips gogear sa52xx 4gb flash video player mp3?
Oct 22, 2010 | Philips GOGEAR SA6045 MP3 Player
Mi gogear SA52XX is in need of new software
try using the philips repair utility to reformat your mp3 player and if that dosnt work try reflashing the firmware on it just goto philips website find your modle and the most up to date firmware for it and try to reflash it
Sep 21, 2009 | Philips GoGear SA5285/37 Digital Media...
Cannot delete playlist folders on my gogear
My gogear SA52XX wont show the names of the songs
Jun 12, 2009 | Philips GOGEAR SA6045 MP3 Player
My Philips SA52xx GoGear MP4 Player won't start up. It just starts starting up and freezes on GoGear, it also makes wierd crackling sounds when playing music... My Philips GoGear used to start up within 10...
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
May 31, 2009 | Philips SA3125\02 MP3 Player
My philips gogear SA52XX won't play videos.
what video format is requird for my phillips gogear model sa52xx?
Apr 28, 2009 | Audio Players & Recorders
My gogear wont load
You need to update the firmware to resolve the issue, but here are some pre-steps:
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 15, 2009 | Philips GoGear Flash MP3 Player
My computer will find my device a philips sa52xx
Make sure the hold/lock is not engaged.
Try a different usb port.
If that fails:
Triple Reset for Philips’ GoGear:
-Tha Mp3 Doctor
Jan 29, 2009 | Philips GoGear SA5285/37 Digital Media...
Phillips GoGear 4Gb - Can't sync songs onto player...
This is only a makeshift solution.
I use a philips gogear sa52xx and found out, that deleting the drivers, then reconnecting the Player and pressing F5 in the explorer allows me to normally access the philips gogear sa52xx for about 30 seconds. After that, out of nowhere the drivers will sever and the Code 10 error appears. So, another disconnect - deinstall of the driver - reconnect - F5 in the explorer until the Player appears and then sync. The proplem is, that this works best (maybe only) with mp3 files...
So convert your music files into mp3 first, than do above steps for drag 'n' drop.
Usually, you need to do the whole procedure 2 times for a CD, sometimes 3.
Oct 31, 2007 | Philips GoGear SA178 MP3 Player
Philips GoGear SA5245/37  Digital Media Player Logo
174 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
