Question about Refrigerators
My Ref.wount make ice - Refrigerators
I have a friend who has a kenmore coldspot Model# 7028999 Serial # EJ5040321 and it won't make ice there is water to the coldspot from the angle stop. A new pump was acquired and installled, but no water reaches the ice cube tray area. When ewater is poured into the ice cube tray area by hand, the ice cubes are made and the machine dumps them into the ice holder. What is the reason for no water from the angle stop to the ice tray? could there be an electric switch in addition to the pump device? Bob 512-762-4585
Posted on Apr 26, 2008
What does the tubing from the ice maker water valve go into when you feed into the funnel of the ice maker?
There is probably Ice forming in the end of the water line. I fought this battle for a long time. Then I found the answer. The Freezer temperature is probably too cold. I have read that the temperature must be set to between 0 and 4 degrees. WRONG. It should be colder than 10 degrees and I have found best results with the freezer set to 6 or 8 degrees on the control panel. To test this. Take a blow dryer and heat up the area where the water comes into the icemaker. Use caution it is possible to melt some of the plastic in that area. Then, set the freezer temp to 6 or 8 degrees. It will probably work fine.
Jan 08, 2017 | LG Refrigerators
G16farxxqo7 ref wont make ice where is water valve
So you want it to make ice water. And it comes out not frozen.
Is the water cold? if it is cold then it is making ice water ok.
Ice water is never frozen, only ice is frozen.
Dec 21, 2013 | managemylife.com
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
WHY IS ICE BUILDING IN THE AREA WHERE ICE EXITS MACHINE (BOTTOM) & INSIDE DOOR EXIT? THEREFORE, INTERFERING OPENING THE DOOR. I HAVE REMOVED SEVERAL TIMES & IT HAPPENS AGAIN?
this ice is coming from the air after you open the door of your ref.the cold air goes down and the hot air enter to your ref. the hot air is highly on humidity that cause of building of an ice. try to fix your door maybe the doorgasket isnot align that has leakage of cold air on your ref . avoid too much door openings. or try to defrost your ref. weekly.
Feb 13, 2011 | KitchenAid Refrigerators
Water does not come out of door. I can hear the click and the ice is working on the other side so it is getting water.
check your water tank in the ref. looking under the veg. drawers. there it should be on the back of ref. if no water than your solenoird in back of ref. might be bad. there is two one for ice maker one for water.. ok
Feb 11, 2011 | Whirlpool Refrigerators
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
My Whirpool ref. stop making ice. There is water
feed valve most likelly cause remove wtr. line if water comes out water valve is somthing to look at if it has power
Jan 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My kenmore is leaking water once a day .
You didn't say from where. Usually twice a day your de-ice heating coils come on and melt any ice that has accumulated. this water usually runs down the back of the ref. and collects in a small pan under the ref. Someime ice form around the hole that the water drains down through to go into the small pan. so then when the deicer comes on the water just runs down the bottom of the ref and onto the floor. My Kenmore does the same thing. Remove everything from the bottom of the Freezer look in the back at the bottom see if hole is clogged with ice. Remove ice then pour hot water down hole check occasionally.
Aug 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice will not eject from door.
their is a control board on back of the ref. this board controls most of the components to ref.i have seen alot of the ge ref. with same problem.replacing control board should solve problem but the board is very pricey.is ice coming thru door worth a couple hundred dollars?
Jan 10, 2009 | GE Profile PSI23NCR Side by Side...
Combo75 icemaker
hi,
make sure you have enough stock in your ref. for the supplied water for ice maker not to be frozen. or if sometimes you have less supply inside your ref., then put some gallons of water and stock it in your ref. and in your thermostat steady to the lowest setting.
Oct 11, 2008 | U-Line Refrigerator Ice Maker
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
