Question about Element Electronics FLX-3211B 32 in. LCD HDTV
We are moving, can't find manual... how do we disconnect the base from the main TV to get it back into the box?
Remove 4 large screws from back of base. Make sure someone is holding the screen as it tilts slightly forward then up to remove.
Posted on Aug 14, 2010
How do i disconnect the smart tv from netgear
think you have to find main menu on theTV then select input.
Oct 21, 2014 | Vizio Televison & Video
Disconnected the baseboard heater - turned power back on - no power
If the breaker (you mean from the main board?) is turning off there is a line fault or short somewhere. If the breaker is not kicked off then there is a loose connection or maybe a small blown fuse in the base board heater unit itself.
Feb 17, 2014 | Heating & Cooling
The tint keeps changing from a red base to a green base and back again, what could be causing it
Hi Check the componet cables, especially if you are using HDMI connectors. Also if you are using a cable box disconnect if from the tv and run the cable signal directly to the TV to see if problem persists. If all cables are connected tightly and secure, then replace the main digital board.
Jan 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
The bottom stand
Is that the 'neck' part between the flat base and the TV? You should have disconnected the neck part from the back of the TV... Instructions are in the operators manual.
Apr 07, 2010 | Samsung LE22A457 22 in. LCD TV
DGTEC top box,DG -HD8710, lost manual when moving
The main aerial goes into the box,then a flylead out of the box into the tv(if you have a vcr or dvd rec then it will go in there first then out into the tv).Then connect the box to the tv with a scart lead.
Nov 07, 2009 | Televison & Video
Hi my name is matt, i took the the back cover off and saw that there is an arc of electricty thats constant and makes a popping sound at the back of the picture tube, also noticed a spark on the main board...
hi ,matt
pls don' t open TV back cover it your self becose inside the back cover very High Voltage [more then 29 KV] EHT is working and she is wery dengures in tv on condition
your tv problum is EHT or CRT base so pls check and replace this spear with qualify technicean.
i think CRT Base in focus pin is sperked and pictur on screen is out of focus .Replace CRT Base with NEW . it 's not Expanciv spear.
Oct 30, 2009 | Zenith C36V23 36" TV
E17 and V141
I had the same problem after I moved to my new home.... The main E2600 base/machine/phone worked fine, but the satellite phone did not. It just kept flashing E-17.
I took the batteries out for a few seconds and reinstalled, and when I put the phone back on the satellite base, it found the main base and worked fine.
Hope this helps.
Dec 31, 2008 | AT&T E2600B Cordless Phone
Remote signal not detected.
Yes, more-so than in a conventional crt based unit without all the extras... You'll need to disconnect many more wires and attachments to get the main board removed then it's about the same job to de-solder the detector and solder a new one in... If you need, take pictures from several different positions in case you stumble getting it back together and can't figure out were a set of wires go to or something. I would order the Ir sensor before you start the job, p/n# 72796410 maybe from Vance Baldwin...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Nov 19, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
66 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
