Question about Acer Aspire™ T180 PC Desktop
Screen does not come on when pc is turned on.
Computer does not boot or something else is wrong. screen does not come on when i turn pc on. tried everything at tech support.
  • Anonymous Apr 27, 2008
    none
  • Nathaniel W. Parsons
    Nathaniel W. Parsons May 11, 2010
    does power lights on front of pc light up? Are all cables securely plugged in on pc and in the right slots?
    Problem Solver:
  • 6 Answers
Check your vaga cards
Posted on May 26, 2008
  • pradeep  kumar
    pradeep kumar May 26, 2008
    check processor and SMPS power supply
Computer
You may want to try holding in the off button for about 30 seconds this is called a hard boot it should turn off before the 30 seconds is up but give it that amount of time at least if it doesn't turn of then there is something very wrong i am afraid
Apr 04, 2013 | HP VM114UA notebook
What do you do when you get a blank screen?
1) You should try restarting it, maby that will solve the problem.
2) If that does not happen, then go to a computer specialist, there maby is something wrong with your Display.
Jan 10, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
My laptop turns on normal goes to window and then shuts down
The is something wrong with the booting of the computer. Does it pass the initial BIOS boot screen? Try pressing F8 once every second after pressing the power button and see if you can boot the computer in safe mode.
Apr 13, 2011 | Gateway Computers & Internet
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
No screen bootup on delld800 screen doesn't come on when i power up.
Hey there!
Try this thing.
First make sure the computer turns on,
It's a no boot issue if. After you turn in on then you see the dell logo then after that black screen,
But if after you turn the computer you don't anything
check if the power button is solid green,
if it is then it was able to complete the POST process,
if that is your situation then try to plug in an external monitor, If you don't have one try to press D+power
while computer is off,,
But if your situation is really a no boot problem
the you will be able to see the DELL logo when you turn on computer the when you see that start tapping on f12 then run diagnostics on the hard drive, if it passed then there is something wrong with the OS,
and i suggest try to back up files.
Hope this helps!
Mar 19, 2010 | Dell Latitude D800 Notebook
MY SAMSUNG SYNCMASTER MONITOR SCREEN DOES NOT COME ON WHEN I TRY TURNING IT ON. HOWEVER THE POWER BUTTON BLINKS GREEN. ANY ADVICE? THANKS SAMSUNG SYNCMASTER Monitor (black) 739S O seen at the back
The cable connecting to the PC might be loose, or the part entering the monitor could be.
Try turning the monitor on, and after a few seconds, turn on the computer. You should be able to see the BIOS POST screen text flashing by. If you can't, there is something wrong in your hardware settings.
If you can, however, that's the OS resolution set too high: the monitor shuts down to protect itself. Boot in safe mode by pressing the F8 key immediately after powering up, then lower the video resolution in Control Panel display settings to something safe - 1024 x 768 usually does the trick. At that point you can reboot in normal mode and raise the resolution again to the maximum supported by the monitor (check the manual for that).
Oct 31, 2009 | Computers & Internet
I disabled the network but now I get a blank screen I was getting
It sounds like the computer might be wanting to go a PXE Boot ...
sdef_definition.gif - Preboot Execution Environment (PXE) refers to various methods of getting an IBM-compatible computer, typically running Windows, to boot up without the need for a hard drive or boot diskette. The methods evolved from the era before computers had internal disk drives.
PXE usually involves booting a computer from firmware -- data contained on a read-only-memory (ROM) or programmable read-only-memory (PROM) chip
* Could something wrong in your computer SETUP. Go in Setup (usually f1 or some key right after turning the computer on) and check that there is not a PXE boot from Network or something like that enabled. Could also mean hard drive has went bad.
Jul 07, 2009 | Computers & Internet
Won't boot..
dear,
u unplugged everything and it booted up finely.
its mean that there is something wrong with the drviers.
check it one by one. just plug hard driver first and let is boot. if its still behaving the same as after plugging all then the problem is caused by the hard drive.
regards,
Aug 14, 2008 | Acer Aspire™ T180 PC Desktop
Sony notebook problem
put os in cd drive and boot up to install new copy .if system says ** os found you k**w you have hd problem you can try to fix or reinstall new copy anyway.remove hd and re seat it first.check mem .remove ,check connections and replace.go into bios and select default.save and exit.
see how you get on .
sounds like missing or conflicting software but try all the above first.If it is missing or conflicting software pretty easy to fix.let me k**w
Mar 09, 2008 | Sony VAIO VGN-N250E/B Notebook
Booting and dvd drive not detected
i'm not sure if your pc has a floppy drive, but if it does, then get a win 98 or win ME startup disk then power up and then push the F8 key (or DELETE key) to enter BIOS setup then select boot floppy then and insert into slot then reboot then boot minimal then get to c: drive and run CHKDSK/FIX then try again, w/out floppy. if no-go then repeat back to c: drive and delete the PAGEFILE.SYS file (may need to attribute the file to allow delete) then reboot w/out floppy
Jun 02, 2007 | Compaq Presario V4000 Notebook
Acer Aspire™ T180 PC Desktop Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
