Question about Garden
Hello there i have a masport lawnmower. i need to change blades but cant get blade holder of shaft
5 Suggested Answers
  • 40 Answers
SOURCE: Masport Lawnmower won't start
you likley will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder.
Posted on Mar 31, 2009
  • 376 Answers
SOURCE: What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
Posted on May 17, 2009
mowerman1857
  • 389 Answers
SOURCE: HOW TO REMOVE MTD BLADE ADAPTER AND INSTALL NEW
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time. Slide the new one back on and repklace blade and bolt(s)
Posted on Sep 14, 2009
  • 1116 Answers
SOURCE: how to remove the blade from the Masport lawn
There is a nut in the center of the blades. The easiest way to remove this nut is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock the blade from from turning and you will need a long handle ratchet in order to give enough torque to remove the nut. Once the nut is removed, the blade will slide right off. If you are doing this to sharpen the blades, you do not need to remove the blade to do this. Use a 1/2 HP grinder wheel and just evenly slide the wheel down the blade until it is sharp. CAUTION: it will cut you finger. Make sure you disconnect the power and the fuel is turned off at the time you do any of this work....
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 09, 2011
My masport mulching lawnmower making a clunking sounds when it's going
Blades could be hitting dead grass under mower deck,or the blade is loose !
Feb 22, 2015 | Garden
How to change blade boss on briggs &stratton sp 470
Unscrew the central bolt (9/16") - remove blade and any washers etc. It's a conventional right hand thread (anti-clockwise to remove), but may well be extremely tight. If necessary, grind the head of the bolt off and replace it.
The blade boss slides off the shaft - in theory. In practice, you will probably have to use a puller bearing on the blade bolt to pull it off. Remove the drive belt first!
Sep 21, 2014 | Briggs & Stratton Briggs Stratton...
Honda lawnmower blade broken at shaft
How To Remove Lawnmower Blade Adapter
If it's the blade that is broken, remove the two bolts that hold the blade onto the blade adapter. If the blade adapter is broken, it needs to be taken off the engine shaft. The Link shows a video on how to remove a blade adapter. Hope this helps......
May 01, 2014 | Garden
Portercable 737 tigersaw can't keep a blade in the quick latch
You can try spraying some lubricant into the blade holder. Sometimes the "ball" in the shaft gets stuck from dirt. Otherwise you will need to disassemble it by removing the roll pin that holds the collar on the shaft.
Mar 08, 2014 | Porter Cable Variable Speed All-Purpose...
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
Can't loosen nut to change lawn mower blade
you are going to need a impact gun to get it off
Apr 28, 2013 | Garden
Does briggs&Stratton have shaft extensions to lower my blade 1in. or 2
are you sure you have the blade on the right way or the right blade for the mower?
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
I Have a push mower and hit a rock and finished the lawn hearing the lawnmower blade hit underneath a couple of times. When the mower went down slope the blade started really hitting the side. The next...
hi there nchernuka
have you checked that the engine to chassis bolts are still tight and the mounts are ok,
have you checked that you havn't bent the pto shaft ( this will be evident if you remove the blade carrier and blades, then the plug and pull the gine over - check wobble ), check that blade carrier is in good condition and the pto woodruff key is ok and the carrier centre pto bolt is tight
check that anything that is under the mower body is still tightly attached and is not getting swung into the path off the blades - ie catcher tounge - metal body brackets etc
i would also suggest you check the feather timming key in the flywheel too especially if it kicks back when you try to start it
cheers have a look
hope it helps pauly46
May 27, 2011 | Garden
My toro lawnmower (brand new) it doesn't start.\r\...
The drive shaft might just need to be oiled. Turn the mower over and locate the drive shaft, where it goes from the mower's blade up into the body of the mower. Lubricate the area of the shaft that disappears into the body with WD-40 or another lubricant, then turn the blade by hand (be careful!) and squirt some more oil.
Eventually the blade should become easier to turn, and then your pull cord should extend without getting stuck. Good luck!
May 20, 2010 | Toro Lawn Mower With Toro Power Tools
The blades on my Flymo 350 lawnmower have become blunt. How easy it is to replace them once i have purchased replacement blades?
It is a matter of unscrewing the bolt that holds the blade on just make sure when installing the new blade that it locks into the mounting shaft correctly on some mowers there is a mating hole to shaft pattern that allows the blade to interlock onto the shaft yours may just have a rectangular support the blade fits into just make sure when you tighten the blade it is set into the shaft correctly and you are wearing a pair of raw hide gloves when holding the blade as you tighten or somehow block the blade with a piece of two by four wood.
Sep 11, 2009 | Garden
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
