Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water does not dispense thru my whirlpool ice/water refrigerator door. The ice maker is working but no water will dispense.
  • Anonymous Mar 17, 2014
    Whirlpool refrigerator ice maker doesn't fill with water
    President:
  • 1,099 Answers
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Hope this helpout......
Posted on Aug 04, 2010
ICE MAKER WORKING BUT NO WATER COMING
The water dispenser and ice maker solenoid comes as a set it is very possible the dispenser side for the water valve is defective. Get the model number of your refrigerator and click here=> sea_breeze_35.jpg and then enter model number for your 25.4 cu. Ft. SxS find part number in photos and replace the part number for your whirlpools dispenser solenoid. Easy to do and much less expensive. If you need help let me know because its a lot cheaper than calling a technician.Let me know, I will be glad to help you, Sea Breeze help you, Sea Breezesea_breeze_36.jpg
Dec 24, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice will not dispense. Ice maker working and water will dispense.
The micro switch that activates the auger is likely failed.
It is at the top of the fountain lever for ice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2010 | Whirlpool Centralpark 25.6 Cu. Ft....
My ice maker has stopped working, the water continues to dispense thru the door yet the ice has stopped
Most likely the water control valve on the rear of the refrigerator is defective for the ice maker side of the valve. Try filling the ice maker with tap water and let freeze. If the ice drops and cycles and does not refill then the water valve is the problem. If the ice maker does nothing when you try this the ice maker is the reason. Send me your model number and I can tell you the parts that need replaced. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker does not make ice. water will dispense thru door and I replace the water filter every six months.
I had the same problem. There is air in the line therefore you need to dispense about 3 gallons of water from the dispenser and that should slove the problem. Also, take a clean soft cloth or paper iowel and wipe the ice make sensor (if you have one) and the reciever. There is one on each side of slightly below the ice maker. Should be a flashing or steady red light ....follow the flashing red light to the other side.
Oct 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool refrig water dispenser and ice maker stopped working
It sounds like the filkter may be plugged up or frozen. check the outlet of the filter to see if the water is going thru. Good Luck and have a Happy New Year.
Jan 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Whirlpool ED5GTGXN000 and the ice maker stopped working. Water dispenser is still working.
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 04, 2008 | Whirlpool Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
518 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
