Question about Epson AcuLaser C4000 Printer
I'v got worn transfer unit on my Epson C4100, after replacing transfer unit message stay's. I can reset message in menu but after restarting printer message appears again.
3 Suggested Answers
  • 14 Answers
SOURCE: Worn Photoconductor Epson C1900 laser Printer
hi this solution has already been covered in full lengths. Epson c900 and c1900 are similar. have a look at my posting on this. photoconductor reseting by Labatt in this forum. read from the start.
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
Posted on May 22, 2008
  • 11 Answers
SOURCE: error code eq023 & worn fuser unit appears even after changing to new fuser
transfer belt cleaner error
replace the transfer belt unit
Posted on Sep 06, 2009
I've getting the "Replace transfer roller" message
  1. reset count in printer menu
  2. clean the optical sensor
Mar 15, 2011 | Dell 5100cn Laser Printer
Epson aculaser c2600 error e114
This means the transfer unit has reached end of life and should be replaced.
To reset the message you must enter in a maintenance mode
Press back+up+down+enter and switch on the power.
In the maintenance mode Scroll trough to "Reset Tr counter"
Oct 15, 2010 | Epson AcuLaser 2600N Printer
Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Nov 12, 2009 | Epson AcuLaser C2600N Printer
Install photoconductor
the photoconductor is commenly refered to as the "drum" .. its the cylindrical part that picks up and transfers the toner to the paper .. the error message might be telling you its time to replace the drum (they do wear out) or perhaps its not detecting the fact that it is in place .. the photo conductor drum is user replacable so it comes out without too much trouble .. sometimes its part of the replacable toner tank .. it would get automatically replaced when you change toner in that case .. be very careful with the photoconductor drum .. any scratches, finger prints or other damage will show up in the printed output .. dont expose it to bright light ...
Oct 01, 2009 | Epson AcuLaser C4100 Printer
Worn transfer unit
The printer is giving you early warning to buy a new Transfer Unit, which on many other printers takes the 4 seperate colours from each toner, building the full graphic page before transferring the complete page onto the drum unit prior to applying it to the paper. My info on this model does not show a transfer unit being available. Perhaps the mean the drum unit? Your printer manual should tell you, or simply contact your countrys Epson centre.
Cheers
De Judge
Sep 15, 2009 | Epson AcuLaser 2600N Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Aculaser C2600 "clean sensor" message won't clear. Have just replaced K toner and it printed about 300 copies then stopped with the message. opened cover and closed it but after calibrating the message...
This is a common characteristic which arises from using improperly remanufactured toner cartridges.
Otherwise it is a bad Epson original one - which is highly unusual!
When the C2600 runs through its calibration it prints strips of each colour on the transfer belt which are sensed for density. You will get a "clean sensor message" if the reading for any of the strips drops below a certain value.
The first thing to do is to depress the clean sensor lever behind the front cover several times . If that doesn't fix it I would advise you to remove each cartridge in turn (go to reset menu and scroll down to change toner) and inspect the toner on the surface of the roller. If there is any form of "sheen" then you'll need to replace the cartridge.
It is possible to adjust the doctor blade if you know what you're doing but be careful as there are shims on each side. Loosening and moving the blade bar towards the roller slightly, refixing and then turning the side cog to rotate the roller can sometimes resolve problem. Not a good idea really unless you're in an emergency.
There are some good remanufactured cartridges and bad ones. If you want to avoid this buy genuine Epson cartridges - I know they're expensive but what does the down time cost!
Jan 14, 2009 | Epson AcuLaser C4100 Printer
Transfer Belt
You need to reset the printer in the menu. There is a option in the menu where you tell the printer that you installed a new transfer kit.
Mar 03, 2008 | Epson AcuLaser C900 Printer
Samsung CLP 500 series Laser Printer
If the messages are because the two units have reached their rated page count, you need to reset this via the printer menu system - see user handbook
Nov 12, 2007 | Samsung CLP-500 Laser Printer
Epson AcuLaser C4000 Printer Logo
293 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
