Question about Sony Ericsson G900 Smartphone
Touchscreen not responding - Sony Ericsson G900 Smartphone
    President:
  • 1,099 Answers
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Hope this helpout........
Posted on Aug 04, 2010
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
Touchscreen not responding. Frozen
Two thing can cause this. If your unit is running firmware version 5.3, this version has a bug where the touchscreen will work for about 5 seconds then the unit will lock up. Updating the unit to version to version 5.4 will fix the problem. More info can be found here:
http://www.sharc.net/discus/messages/6/471.html?1337567850
http://www.sharc.net/discus/messages/6/469.html?1333569932
If you are running firmware version 4.9 or 5.4 and the touchscreen still does not respond, then the touchscreen will need to be replaced. On the Nuvi 7xx, the touchscreen may be soldered to the LCD display, so if you don't have any soldering experience, please have a professional replace the touchscreen. More info can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Mar 23, 2013 | Garmin Nuvi 760 Car GPS Receiver
Touchscreen doesn't respond
Sounds like it didn't install correctly, you may want to check the digitizer on the glass panel
Oct 06, 2012 | Motorola Mobility DROID BIONIC (16 GB)...
Touchscreen does not respond to touch .
CHECK THE FLEX OF UR TOUCHSCREEN IF ITS BROKEN;IF NOT JUST LIFT THE SOCKET AND PLACE IT AGAIN.
Jul 27, 2012 | Handspring PalmOne palm treo 600 Silicone...
My buttons on my phone works but my touch screen is not responding to anything at all.
check MENU settings may be touchscreen is off ,else touchscreen loop is broken
Aug 02, 2010 | Cell Phones
The touchscreen will not respond, but there hasnt ...
You may not see the damage but, it might have been damaged somehow. Take it to phone shop to be examined. Thanks
May 20, 2010 | Lands Phones
Try to find how to calibrate the touch screen in the users manual.
May 29, 2009 | Garmin nuvi 250W GPS Receiver
Treo600 Touchscreen doesn't respond.....
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus
Jan 14, 2008 | Palm Treo 600 Handheld
Sony Ericsson G900 Smartphone Logo
704 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
