Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet front load 7 cu ft electric
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Posted on Aug 14, 2010
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
Dryer won't turn on believe it's the start switch,has power,the timer is working and the door latches
if the timer is working and counting down, you need to open the door and spin the drum, if it spins real easy , with no resestance you need to check your belt,, if the belt comes off or breaks it has a micro switch that shuts the motor down, but the timer and lights will still work
Jan 19, 2011 | Kenmore Kitchen Ranges
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
521 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
