Question about Sony Playstation 3 (PS3) Console
Trying to set up my ps3 on a technika tv but it doesn't seem to connect, Have a hdmi cable and scart cable but the scart is only 12 pin. Do i need to get a 21 pin scart lead? It works fine on my samsung tv but not the technika
3 Suggested Answers
madhatter639
  • 260 Answers
SOURCE: Hdmi cable works but the av scart cable tht I got
This is a typical problem with the PS3 after you hook it up to your tv with an HDMI cable. You will have to reset your PS3 to get it to work with just the a/v cable. To do this, turn off the PS3, unplug the PS3, wait a minute or so and then plug it back in, press and hold the power button until you hear 4 beeps (1-1-2), You may have to power cycle the PS3 a couple of times or more for it to do the 4 beeps. After the 4th beep take your finger off the power button and follow the directions and prompts on screen. This could erase all of your saved data when you do this. Please leave feedback and a rating vote on the info I've provided.
Posted on Jul 02, 2010
BADBOYJAY
  • 271 Answers
SOURCE: Green dot's and pixelation via hdmi
all you need is to go down the computer shop and tell them they will sort you out with the right leads you are using the wrong leads the ones that come with it will be ok but not so good pictucer when you get the right ones you will be very happy
Posted on Jan 04, 2008
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
Technika tv/jvc combi player
SCART Cables come in two kinds 9 pin and 21 pin ensure you are using correct type in user manual. What other connections are available to you?
Jul 21, 2014 | Audio Technica Televison & Video
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
My ps3 will not put out any audio or video
Have you changed your settings from hdmi back to normal you should try both hdmi and scart or av on your tv, if this doesn't work then you need someone with a ps3 that works (you need your ps3 and a spare tv) and you can copy what theres does but you need to be very precise or look on you tube to see how to restore your ps3 back to the factory settings. I hope this helps mines done the same and it worked for me.
Apr 04, 2012 | Sony PlayStation Video Game Consoles &...
Im trying to get my ps3 to connect with another tv
turn off ps3 till the red light is on the machine then you need to hold down power button to turn on until you hear a beep.
make sure a hdmi cable is not connected at back of ps3.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Jul 03, 2009 | Televison & Video
Ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
554 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
