Question about FEC RKMV5 Custom Rackmount Kit for JVC RKMV5
GOOD EVENING HOPE YOU CAN HELP ME AFTER BURNNG MUSIC OR DVDS ON MY COMP I TRY TO PLAY IT ON MY DVD PLAYER I GET A MESSAGE NO TITLES RECORDED CAN NOT PLAY THIS DOES HAPPEN QUITE OFTEN MY DVD RECORDER IS A PANASONIC DMR-EH50 REGARDS BRIAN
I can not get my DVD to play after dubbing. A message comes up, no title.
dvd+rw is garbage, organic dye in the layers breaks down fast, always use dvd-r. dvd-rw also has compatible reading problems with many dvd players, hope that helps. also you need to make sure it is finalized for another dvd player to read it
Mar 19, 2014 | Sony RDR-VX560 DVD Recorder/VCR
I have a JVC DVD & HDD video recorder (DR-MH30S). I use it regularly to record to hd, but cannot dub successfully to dvd. The dvds work in that machine but not in any other dvd players, or even my...
are you able to atleast view and play the files in your computer?
if so then there is no problem with the recorder.
what is the format in which it records the files?
Sep 18, 2008 | Televison & Video
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hi i have a sharp hp22 i ham trying to play normal dvds on it ? is that possible
All Blu Ray players that I have dealt with are what is termed "backwards compatible" which means they play Blu Ray, standard DVDs,music CDs,MP3s,recorded CDs and DVDs, etc. yours should have no problem reading and playing back your "normal" DVDs. Good luck !
Dec 27, 2009 | Sharp BD-HP22U Player
Philips DVP3020 plays CDs but not DVDs
Try running a good quality dvd cleaner. After the cleaning cycle try a known good dvd & see if it plays. Hope this helps.
Jan 22, 2009 | Philips DVP3020 DVD Player
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
26 people viewed this question
Top FEC Televison & Video Experts
Marvin
Marvin
Are you a FEC Televison and Video Expert? Answer questions, earn points and help others
