Girlfriend has an Acer 4520 Notebook; HD burned out; replaced with new one. Had to buy new recovery discs from Acer- 1 system disk and 2 recovery discs. Couldn't get to installing until a month later, and went well until unit couldn't "see" the third disk. Install incomplete, making it a great doorstop. Acer won't replace the disk, but would gladly sell me another one! Nice... Anyway, what do I do now? Any way I can download the contents of the third disk (second recovery disk) from the net, burn a disk, and continue installation? Thanks for any help...
  • swedekid Aug 04, 2010
    Perhaps more info needed with this problem: I installed a brand new HD into this Acer 4520 with no problem. 1-System Disc and 2-Recovery disks were purchased directly from Acer for this model. I was not able to install until a month later, and when I went online to find a solution, they told me that they would only exchange disks, if there was a problem up to 14 days of purchase. As I mentioned initially, the first two discs loaded without a problem; but when I tried to install the third (2cnd recovery disk) a message window popped up telling me to insert the next disk, even after I had done so. Multiple attampts to reload failed. I even duplicated the third disc, thinking that maybe there was something keeping the disc from from reading the original disc; no luck there either, but worth a shot. I'm at wits end what to do next; it's a brand new HD, but I can't get the complete recovery disk process complete. What now?
  • swedekid Aug 11, 2010
    OK, hopefully the third time's the charm- haven't had a useful solution yet after 2 previous attaempts! I'll paste the original post to my problem. Any solutions are welcome! Here's the "pasted" post:
    I'm not sure if you are accessing the original post, so I'll attempt to paste here and add a little more info that may be helpful: Girlfriend has an Acer 4520 Notebook; HD burned out; replaced with new one. Had to buy new recovery discs from Acer- 1 system disk and 2 recovery discs. Couldn't get to installing until a month later, and went well until unit couldn't "see" the third disk. Install incomplete, making it a great doorstop. Acer won't replace the disk, but would gladly sell me another one! Nice... Anyway, what do I do now? Any way I can download the contents of the third disk (second recovery disk) from the net, burn a disk, and continue installation? Thanks for any help... OK- from there,here's what I did: As mentioned, the HD installatiuon was no problem, and began the install process with the 3 disks I got from Acer. After loading the 1st disc- labeled "System Disk"- I proceeded with the 1st of 2 recovery disks. The first one loaded fine, but when I tried to load the third and last disk, a dialog box came up telling me to insert the next disk- repeatedly- like the laptop couldn't "see", or recognize it. Repeated attempts to start from scratch ended up being stuck at the same place. As mentioned, I even duplicated the last disk, thinking maybe there was something physically wrong with that last disk.
    New question: Anything else I can do to finish this installation and get this laptop running again? Thanks...
  • 1,472 Answers
Swedekid
I am not sure if this is been suggested as I can not see the post from the other experts. However when I do the restores from other manufactures I normally have to put back in the first disk after the install of the other disks are done to finallize the restore. Let me know if you still have trouble and I will dig around to see if I can find a disk for you.
Issken
http://www.fixya.com/users/issken
Posted on Aug 11, 2010
  • 2 more comments
  • swedekid Aug 15, 2010
    Thanks for your post! Though it doesn't address my specific problem, it's a little closer than I've gotten with the previous 2 "experts". I will paste original problem and add from there: Girlfriend has an Acer 4520 Notebook; HD burned out; replaced with new one. Had to buy new recovery discs from Acer- 1 system disk and 2 recovery discs. Couldn't get to installing until a month later, and went well until unit couldn't "see" the third disk. Install incomplete, making it a great doorstop. Acer won't replace the disk, but would gladly sell me another one! Nice... Anyway, what do I do now? Any way I can download the contents of the third disk (second recovery disk) from the net, burn a disk, and continue installation? Thanks for any help... So, in a nutshell, again: the 1st disk (the system disk) and the first of 2 recovery disks loaded just fine after installing the new hard drive. The ultimate problem is getting the 3rd and final disk to load. When I try to load it, a pop-up box tells me to install the 3rd disk, but then fails to "see" it. The box keeps popping up, no matter how many times I try, which stops the entire load process. How do I get the laptop to recognize the third disk and complete the installation? Anything else you can offer is VERY welcome! Thanks...
  • Will Hartford
    Will Hartford Aug 15, 2010
    swedekid
    I am in the process of seeing if I can track down another copy of the 3rd disk for you. I did have a side question on how old your computer was. The reason I ask is that there may be a chance the drive does not support over burn and they may have used this to make the 3rd disk.
    So the next question is does the computers boot options give you the option to boot from a USB drive, hard drive or CD Rom.
    Issken
  • swedekid Aug 16, 2010
    Thanks for responding once again! Unless I'm missing something (and I should point out I'm not a geek by any means, just a casual computer user) this computer is essentially stuck until the install is complete. I seem to recall something mentioned about hitting F8 on start-up to bring up the boot options- is this what you're referring to? I can't remember if I've tried that, since I've spent the last couple weeks trying to find answers to why the machine won't "see" the third disk and throwing up the dialog box. I can only guess the disk got corrupted at the factory, but it's hardly a point now. Anyway, if I'm on the right track with the F8 (or is it F10?) please let me know what the steps are and what to do next. I can't believe I'm having such a hard time on a simple install! Thanks again for any help you can offer. Let me know if there is any additional info you need to get me rolling again!
  • Will Hartford
    Will Hartford Aug 16, 2010
    swedekid
    Sorry have not been able to find a free copy out there to try to replace your disk 3 with.
    In regards to my question about the boot menu you should get to it by hitting F12.
    The next question do you have access to an external drive and/or know someone that you can borrow one from.
    The idea is to copy all the files to the external drive as long as you do not over right any files you should be able to run the reimage off the hard drive with out having to change the disks out. Hopefully if the file names are not the same on both disks it will work. I have had to do this before installing programs on systems that did not have DVD drive or an older ROM.
    Let me know what you find out
    Issken
    President:
  • 567 Answers
Hi you mention you have a system disk,have you use it to install the operating system as yet?.
Posted on Aug 04, 2010
  • swedekid Aug 05, 2010
    OK- from there,here's what I did: As mentioned, the HD installatiuon was no problem, and began the install process with the 3 disks I got from Acer. After loading the 1st disc- labeled "System Disk"- I proceeded with the 1st of 2 recovery disks. The first one loaded fine, but when I tried to load the third and last disk, a dialog box came up telling me to insert the next disk- repeatedly- like the laptop couldn't "see", or recognize it. Repeated attempts to start from scratch ended up being stuck at the same place. As mentioned, I even duplicated the last disk, thinking maybe there was something physically wrong with that last disk. Any new suggestions?
    Sergeant:
    Champion:
  • 256 Answers
What happened why did it not install at the first instance you bought it? Usually for recovery cd contents, those are not available on Acer's website, or any website for that matter. If in their sales dept, you still cannot demand for that third disk which you've paid for, I suggest for a last resort, to purchase the full version of your chosen Operating system with Microsoft. But if its only the drivers that is in the third cd, then you could readily download it from Acer's website. If 2 disks will pursue and will let you boot to Windows, then you could just download the other drivers from Acer's website.
Have an aver inspire 4520 dont boot up compleatly and dont have the back up disk
on the acer aspire range there should be a recovery partition hidden by turning your note book off completely then press the power button as soon as you have done this press ALT on the left hand side and keep it down while continuously tapping the F10 button "fast" as this will start the internal recovery partition, if you have formatted the hard drive and this partition does not exist anymore you can go to microsoft or a torrent site and download the correct operating system making sure it matches your Operating system genuine sticker by using this key on the back of your computer you wont have to buy a new operating system, if your hard drive has developed a fault which is the main cause of you doing this then you will have to buy a new hard drive to replace it with using the same method above if you need further help please drop me a line, If i have helped please rate me Kronoguy
Jul 08, 2011 | Acer Aspire 4520-5582 Notebook
Hello, I have Acer Aspire 4520 laptop, I tried to upgrade my HHD from 160 to 250...but I used the recovery disc that I created on the older System drive to the new one is it possible? the problem is, it...
The upgrade from one disk size to another is TONS easier if you were to clone the old hard drive. If you recover, EACH AND EVERY program will need to be reinstalled, and you will need to install all of your data.
Alura-tek makes a clone device, but it will take two steps, first clone, then you have to reallocate the unused space into your C:\ drive (or you will still be 160 GB).
Do you have good backups of all of your data? That has to happen first.
Feb 17, 2011 | Acer Aspire 4520-5582 Notebook
WANT TO RESTORE ACER ASPIRE 4520 TO ORIGINAL FACTORY SETTING BUT HAVE NO RECOVERY DISK
Hello, If your system is capable of doing a Recovery via Hidden Partition on Hard Drive, you can access it by Pressing Alt + F10 and choose Recovery Option.
Apr 23, 2010 | Acer Aspire 4520-5582 Notebook
Where can i buy a recovery CD for my Acer Extensa
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press <F2> during POST.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 10 GB in a hidden partition on
your hard disk.
Apr 09, 2010 | Acer Extensa 4620 Notebook
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
Error 0XC000000C and 0XD000001E and 0XA0000001 how would I fix these errors its on a Aspire 5315-2153 Notebook did have Window Vista as OS I tryed the backup disc I made 1-9 error OXC000000C on disc 7 I...
My 0xc000000c "Restore Failed" prompt seemed to be the result of disk surface damage on the restore disk. After burning the restore disk to a new disk, the restore proceeded normally. Try making a copy of the original restore disk to a known good blank disk.
Jul 20, 2009 | Computers & Internet
Black screen NTDLR Press any key to restart
Are you saying it came with a recovery disk that you dont have anymore. If thats the case you may need to aquire this from acer. If you go to their web site you can usually find a way to order this disc for your machine.
Find someone who has an xp disc and use it to go to recovery console then restore MBR files. NTLDR is the error meaning your master boot record has been damaged.
Char S.
May 27, 2009 | Acer Aspire 5102WLMi Notebook
I need to know how to avtivate the system restore for the computer for a ACER ASPIRE 4520 sincei dont have the disc??
Jan 11, 2009 | Computers & Internet
Acer m5100 recovery discs
Restore disks are available from Acer. If you complain loud enough they may even send them for free.
Dec 13, 2008 | Acer Aspire 4520-5582 Notebook
Acer 1690
They may be correct, although you can try pressing F8 on boot up and and enter safe mode. When in the menu choose 'Last Known Good configuration' and press enter, allow a reboot and hopefully you get into windows. It may also be the boot.ini which is damaged at tells the harddrive where windows is, but you will need your Windows disc to repair the system.
Apr 09, 2007 | Acer Notebook
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
