Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Just wondering if my baracuda cleaner can be run with the pool cover on. In ground pool with steps.
  • 640 Answers
These automatic pool cleaners are not designed to be operated with the cover in place.
Posted on Aug 04, 2010
  • 106 Answers
Much better if you have the hoses that sink, not float. The action of the hoses rubbing on the cover will affect where the cleaner goes. I would suggest not cleaning while pool is covered.
4 Suggested Answers
SOURCE: baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
Posted on May 03, 2009
  • 106 Answers
SOURCE: I have a baracuda pacer pool cleaner and it seems
A coupe of things you can try. Either add one hose length or take one off. If that doesn't help, you can reverse the hose positions.(take the first one off, and put it last. Change all of them) Also, changing the amount of suction may help.
Posted on Apr 19, 2010
Testimonial: "thank you for your suggestion I will try this solution of changing the hoses around"
jharwell668
  • 640 Answers
SOURCE: baracuda pool cleaner does not cover the entire pool
With these pool cleaners, there are several things that it could be. Check the return line water flow and redirect as necessary with an eyeball diverter. Make sure the automatic regulator valve is installed properly and is not clogged. Make sure the cleaner has proper hose balance.
Posted on Oct 26, 2010
Baracuda only cleans side of pool how to clean entire pool surface
most of the time that auto pool cleaners "Head for the side" its because customer has set speed too high , need to slow down , consult your owners manual for specfic methods on how to do this , in this case slowest wins the race!!!
Sep 27, 2014 | Zodiac Baracuda G3 Automatic In Ground...
Ihave pulled my baracuda apart and have no instructions on how to put it back together.
Below is a copy of the users manual for these pool cleaners from the Zodiac website. It has detailed instructions and illustrations that will show you how to put the cleaner back together.
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Jan 11, 2011 | Zodiac Baracuda G3 Automatic In Ground...
I have replaced the diaphragm on my Classic. I have even replaced the filter sand. There are no apparent tears in the pipes, yet the cleaner runs for a few minutes and then stops dead, not pulsating. The...
Use Pool Pulse to ensure proper flow. It could feel ok on your hand, but you need very precise pressure to power these pool cleaners. If you are not familiar with how to use the Pool Pulse feature, take a look at the users manual below. They have a step by step guide to this feature.
http://www.baracuda.com/resources/manuals/G4W83408.pdf
Oct 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda pool cleaner stays in the deep end only what is the problem?
If these pool cleaners are not going to one end of the pool, make sure that your hose is long enough and that is it is balanced properly. Improper hose floats is likely the cause.
Aug 14, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Intermittent suction of my baracuda pool cleaner
If your pool cleaner is losing suction, there are several things that you need to check. Check the diaphragm for damage. Make sure that you don't have air leaking into the cleaner. Check all of the returns, hose, and connections for cracks or improper connections. Make sure that the filter is backwashed and that there are no obstructions in the filter basket.
Aug 05, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda X7 stays at the deep end of the pool
With these pool cleaners, there are several things that you can try to get your cleaner to move around your pool. Check to make sure the hose is long enough to reach all ends of the pool and that it has proper hose balance. Check the return line water flow and redirect as necessary with an eyeball diverter.
Jul 23, 2010 | Zodiac Baracuda G3 Automatic In Ground...
MY POOL CLEANER WILL RUN FOR A FEW MINUTES, THEN STOP. SO METIMES IF I SHAKE THE HOSE IT WILL START AGAIN. ANY ANSWERS?
Hi , most pool cleaners run by the force of the sucked up water moving gears inside the cleaner .. if yours is this way, then any blockage in the cleaner or in the hose attached would restrict the flow and keep the cleaner from moving.
Apr 30, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda pool cleaner does not cover the entire pool
Jul 01, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barrcuda inground pool cleaner flips over
Often when you are having this problem with automatic pool cleaners, it has to do with the hose. Make sure that you have plenty of slack in the hose to cover the entire pool. Also, make sure that you do not have any obstructions in the hose and that it is not tangled.
Jun 13, 2009 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
226 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
