No picture or sound
I have a phillips magnavox projection tv model number 9p5534c103 and there is no picture or sound what do i need to do and how much will it cost
  • 8,617 Answers
There is really know way to determine cost. most repair shops will charge at least 100 doolars or more just to go look at the set. something in the power supply either stanby or start up circuitry would be my quess. Do you have any trouble shooting skills? Do you have the service manual?
Posted on Apr 26, 2008
Phillips Magnavox 9P5534C103 need to replace Ics
Check with TV repair.com who sells kits for most of these sets that come with all the needed parts and instructions---you might also look on You Tube who has video instructions for a lot.
This is a older set and the chips will either be on large board to left as seen from rear or to the far right side as seen from rear--the chips are soldered in STK-392-110 OR -120 CHIPS. I can give general instructions if know where they are and what number is printed on the front of them.
Oct 23, 2012 | Philips Televison & Video
Just curious as to how much a philips magnavox motherboard would cost for a 32 inch tv.. installation included
Need the model number of the set to even begin to answer your question since there are so many different Phillips 32 inch models and they all have different components and circuit board designs.
Jun 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a phillip magnavox that needs a color tube but I need the part number so that I can order it. The model number is 9p5534c103 can you help?
Which Tube is it that you need? Look on Encompass Parts Distrb. they have Blue and Green Tube Price is 204.46 1-800-638-3328 And are you sure Tube is Bad Most of the time they have Bad coolant Fuild that needs to be changed For projection coolant fuild,$6.50 a Bottle you need at least 4=$24.00 plus shipping With TV on and playing Look down inside top of ubes if you cannot see picture clearly then chage out the coolant Fuild.It means old fuild is Bad! Mats Electronics 1-800-628-1118
Nov 10, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
IC Chip?
Its a common problem with this model. Goto www.TvRepairKits.com to get the parts and instructions to fix the TV.
Sep 06, 2009 | Philips Magnavox 9P6034C 60" Rear...
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 9P5534C103
Its a common problem with model. Check the site www.TvRepairKits.com for a fix.
Aug 29, 2008 | Philips 9P5534C 55" Rear Projection...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
Philips-Magnavox 9P5534C103 55IN. PEAR PROJECTION
TV does not display picture on whole screen....it has three smaller colored rings with the picture inside of it
Jun 01, 2008 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
