Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
My keyboard do not work. What can i do besids check batteries and check the cable?
  • 10,515 Answers
First of all, we would make sure whether there is a fault with the keyboard or with your computer machine / drivers. Use this keyboard with some other machine. If you would still unable to use that, it would confirm a hardware fault.
As you have already checked the batteries and cable, the only thing you could do is to open the keyboard and clean the keyboard. Sometimes, dust and debris might cause this situation. Also, check to make sure that there is no broken or loose connection. Even after following this,if the same problem persists, it would be an indication of board fault / failure.Usually in those cases, buying a new one is more economical than investing in repair.
Good Luck!!
Thanks!!
Posted on Aug 07, 2010
Asus r503u motherboard manual
This is not a PC Motherboard. The Laptops are different that a standard PC and they do not allow you as much leverage. The task of just getting inside of the computer is very difficult and if you are not experienced at that; don't even try.
Jan 08, 2014 | ASUS R503u-rh21
How easy is it to replace the keyboard on a Medion E1210 (MSI-Wind)??
Real Easy. Just remove the power cord, remove the battery. If there are screws inside the battery compartment remove them because they will either hold the strip above the keyboard in place or they will hold the keyboard. Most times the screws that hold the keyboard will have the icon of a keyboard beside it. Look at all the screws on the bottom of the laptop and see if any of them have the icon of a keyboard beside them, if so remove that screw.
Turn the laptop over and remove the strip that is above the keyboard buy prying it off. You might need a small flat head screw driver to start getting it loose then you can use your fingers. Be careful because there might be a cable under it.
Most times the strip above the keyboard might have hidden some screws that hold the keyboard, if so remove them. The keyboard might also be held by small catches on each side. If that is so work with one side first then the other will simply come out. You might have to bend it a little to get it loose from the catches on the side.
Be careful when you lift the keyboard out, there is a cable that attaches to the motherboard under it.
Jun 04, 2012 | Medion Computers & Internet
Lose Hinge
You might have to remove the Palmrest and keyboard to tighten the screws on the hinges. Have some cups with labels on them so you will know where the screws came from. Turn the laptop over and remove the screws on the bottom. Remove the battery and remove any screws inside the battery case or compartment. Notice some screws might have the icon of a keyboard besides them, if so they hold the keyboard in place. Remove the covers for the hard drive, memory and any other devices then remove them and look for screws inside the case where they came from. Remove the dvd drive and look for screws in the dvd drive compartment that hold the palmrest to the frame.
Turn the laptop back over and remove the strip that is above the keyboard very carefully because there might be a cable under it. You will just have to pry it loose because it snaps in place. The lcd hinges might be exposed enough so that you can tighten them without removing the keyboard and palmrest.
Next remove the keyboard. The strip that was above the keyboard might have screws under it that hold the keyboard in place so remove the screws. Sometimes the keyboard has little catches that hold it on the sides, so just work with one side first by bending it a little to get past the catches. Once you get one side loose you can carefully lift the keyboard because there is a cable that is under it that attaches to the board that you want to remove from the board. Now the LCD Hinges might be exposed so you can tighten them.
May 23, 2012 | Toshiba Satellite A25-S207 Notebook
Remove toshiba keyboard
Remove the Power Cord, Remove the Battery. Look inside the battery compartment and see if any screws are there, if so remove them (the keys inside the battery compartment normally holds the strip that is above the keyboard). If you see a screw that has the icon of a keyboard beside it, then that screw holds the keyboard in place. Look along the bottom of the laptop for more screws that have the icon of a keyboard beside them and remove them. In fact you could just remove all screws from the bottom of the laptop just in case you have to remove the palmrest. Remove the screws from the covers that houses the memory and hard drive and check inside them for screws. Sometimes a keyboard screw might be inside them.
Turn the laptop over and remove the strip that is at the top of the keyboard by gently prying it off with a small flat head screw driver. Be careful because there might be a cable attached to it. If the strip above the keyboard is one big piece that requires the whole palmrest to be removed, then look along the sides and top of the keyboard for little catches that you can push to release the keyboard and it will come out without having to remove the palmrest.
if the you have to just remove the strip at the top of the keyboard, once it is removed there might be screws at the top of the keyboard that hide under the strip to remove. Once the screws are removed, gently try to lift the keyboard out. Small catches on the side might be holding it so you might have to work with pulling one side out first then the keyboard will come out. Be careful, there is a cable under the keyboard that plugs into the board. Remove the keyboard cable from the board then lift it all the way out.
May 15, 2012 | Toshiba Satellite M45-S331 Notebook
E8410 keyboard removal
Remove the power cord, remove the battery, turn the laptop over and remove any screws you see inside the battery compartment. Also look on the bottom and in the battery case for any keys that might have the icon of a keyboard beside them (they hold the keyboard in place). You might have to remove all the screws from the bottom case if the laptop's design does not have a separate strip that sits above the keyboard. Once you have the screws remove, turn the laptop over and open the lid. If there laptop has a strip above the keyboard, then pry it off gently because a cable might be under it. If it does not have a strip, but is all one big piece called the palmrest that surrounds the keyboard, then the keyboard might have little catches on the sides and at the top that you can move and wiggle the keyboard out. if not you will have to remove the palmrest. Also if you have the strip above the keyboard, once you remove it you might see screws that hold the keyboard then remove them.
Be careful when you lift the keyboard out, there is a cable under it that has to be removed from the board.
May 13, 2012 | Fujitsu LifeBook E8410 Notebook...
IMac keyboard suddenly isn't working. Mouse works, but I can't enter any typed message.
if it's bluetooth, are the batteries ok and is it showing up in your bluetooth settings? if it's wired, try another usb port
Oct 21, 2011 | Apple iMac G5 Desktop
How do i change a keyboard?
First you have to determine how the keyboard is held in place. On many units, you remove the battery and look in the location for 2 or 3 screws with a small keyboard icon beside them. Remove those screws and the keyboard will lift off. After lifting it off, note there is a ribbon cable attached to the motherboard. you have to unlock the retainer for the ribbon cable by lifting up on both end tabs or it may have a flip tab for the lock. Be careful not to force too hard, they will break. On other beyboards, you may have to remove all of the case screws until you can determine how the keyboard is held in place. Some only require the speaker cover be popped up and the keyboard will come up. Hope this info helps
Oct 27, 2010 | ASUS Computers & Internet
I have the keyboard for my Lenovo Y510, how do I install it?
basically, there is a pre-installed driver for keyboard in Y510. Check the keyboard if it work. If it is not, then turn off the pc, remove cables and battery.
Press and hold the power button for 5 seconds, reinsert the battery and keyboard then turn on the pc.
Then check if the keyboard works...
Dec 13, 2009 | Lenovo IdeaPad Y510 Notebook
Wireless keyboard will not reactivate when battery was replaced.
Besides replacing the batteries, you need to resynchronize the wireless connection for the keyboard to your computer.
To do this, press the "Connect" button under the keyboard, then press the "Connect" button on your receiver that connects to your computer. That should bring the keyboard back to life.
Aug 28, 2009 | Dell Computers & Internet
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
