Question about Belkin Powerline F5D4050 Network Adapter
I have a LAN modem on one floor. I'm using a Belkin Powerline AV 200 Starter Kit to bring my internet connection to the second floor (220V system). It works when I connect a laptop directly with the Belkin Powerline unit on that second floor. It also works when I use a Netgear 5GHz Wireless-N HD Access Point/Bridge between the Belkin unit and the laptop. It does NOT work when I replace the Netgear AP with a D-Link DIR-635 Wireless N IP Router (which works well when directly linked to the LAN modem. How can I make the D-Link router cooperate with the Belkin Powerline system?
  • dstockhaus Aug 04, 2010
    "Device not detected" ended all attempts to update any firmware
    Firmware upfate worked in the end, but had no effect.
    Genius:
  • 1,035 Answers
Hi. There should be no problem with your setup. have you checked the gateway IP of your belkin and d-link? if they are the same then there might be possible IP collision there and that is why your not getting connection.
Posted on Aug 04, 2010
  • 2 more comments
    Will look tomorrow. The D-Link is already back in the box, and the Access Point is out again. I did set up the D-Link with dynamic ip though.
  • Angelito Rabago
    Angelito Rabago Aug 08, 2010
    any update here?
  • dstockhaus Aug 08, 2010
    Thanks for asking! Nope, have given up. Will get other powerline adapters on Wednesday (D-Link) and test them first. D-Link should work with D-Link (router) - theoretically.
  • Angelito Rabago
    Ok. That should do it. It will be best if you will buy the same brand.
    Thank you for using Fixya and have a great day.
    President:
  • 4,070 Answers
Hi! Have you tried pressing the master reset button on the D link router? This may resolve it so please do try. Hope this helps and have a good one!
  • 1 more comment
    Well, the point is that the D-Link Router as such works perfectly, it is recognized by the PC, but there is no interernet connection. There is no difference with and without the Belkin powerline plugged into the router. Belkin powerline as such does transmit an internet signal, the Netgear Accrss Point shows that (internet connection fine). But the signal is not "enough" to get the router to passing the internet signal to the PC the way the AP does.
  • dj_relly999
    dj_relly999 Aug 04, 2010
    Alright, thanks for the clarification. Have you tried double clicking the connection for the Dlink may need to be identified first before connecting to the internet.
    Yes, have done that.
    Sergeant:
  • 260 Answers
Try setting them up the other way around with the D-Link router connected to your modem and then your Belkin Powerline connected to the network via an ethernet cable to your D-Link router. Often times the wireless router needs to be connected directly to your modem for it to work correctly and then everything else has to be connected to the wireless router. Typically, a wireless router has at least 4 ethernet ports on the back side for connecting other LAN devices to the network that don't have wireless capabilities.
  • 1,183 Answers
I guess the problem is with the compatibility of both the devices. The belkin powerline doesnot work with >100mpbs D-lin 635. You may try downloading the updated firmware from the belkin website.
I'm not sure about the model of the powerline you are using, as it comes in two models in the UK one with 85mpbs and the other with 200mpbs but the updated firmware can be downloaded from the link below
http://en-uk-support.belkin.com/app/answers/detail/a_id/3144
How to update the firmware ?
I would still suggest call belkin to verify the updated firmware
Thanks for using Fixya
Proton
  • 1 more comment
  • Mandeep  Singh
    Mandeep Singh Aug 05, 2010
    Even after the updating the Belkin if the device is not working , the issue could be with device compatibility .I would personally try replacing the Belkin Powerline to eliminate the issue I personally do not have more to add to the solution. But if i find anything on the same , will post back.
    proton
  • dstockhaus Aug 05, 2010
    Thanks, that's exactly my impression. But what powerline device is compatible with the D-Link DIR-635 Wireless N IP Router? Any idea?
  • Mandeep  Singh
    while researching on the issue in I came accross the latest firmware update for the Router.
    The link to Download firmware .
    In certain regions the Dlink router that you are using is End of life.
    However I was able to locate the model number for the Dlink power line that should work with the both the Routers
    Dlink Poweline HD
    Thanks for your time and patience and please keep me posted on the issue
    Proton
I have had a pair of Belkin Powerlive AV adapters (F5D4072) for a while now and they work really well across my house between two routers. I recently bought a 2nd pair of the newer F5D4074 adapters (old...
There are two standards for powerline: HomePlug 1.0, which has a maximum link speed of 85Mbps and HomePlug AV, which has a maximum link speed of 200Mbps. You can use the two standards within the same building, but they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
May 31, 2011 | Belkin F5D4074 Network Adapter
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
Feb 24, 2011 | Belkin Powerline F5D4050 Network Adapter
This thing doesn't work. When moving the remote unit downstairs, it doesn't connect to the network.
The powerline modems are affected by the other connected equipment in your house and the wiring phases.
For BOTH modems try the following first:
-Connect the modems directly to the wall socket, don't use an extension lead.
-If you have a surge protecting extension block plugged in in the next/adjacent socket, try plugging it in on a different mains socket.
If this does not work, you may want to think again about routing an Ethernet cable between floors.
Higher performance and lower cost.
Feb 13, 2011 | Zyxel PLA407 HomePlug AV 200 Mbps...
I have 4 Belkin Powerline adapters, two F5D4074 and two F5D4072. On Belkin website they are declared compatible, but I can't manage to transfer the password between the 72 and the 74, with the result that...
Also try to rest the adapters and reconfigure them again.
Dec 31, 2010 | Belkin F5D4074 Network Adapter
Hi there, I am using Window xp on my desktop and window 7 on my laptop. Lan card on desktop is quantum lan card QHM8100R3D. Problem: I have Belkin F5D7234-4 Router and when i tried to connect...
Verify that you haven't manually set the IP address of the desktop machine to an IP address that conflicts with another device on your network.
If this is the case, change the network settings to use Automatic or DHCP IP address assignment.
If this doesn't fix the issue, I suggest trying a different network card than the QHM8100R3D to see if that addresses the issue.
Dec 20, 2010 | Belkin F5D7234-4 Router
Hi I am using reliance broadband. They have
Easy, if your modem is connected to your computer right now and internet is working all you need to do is connect your LAN line to your belkin router. the connection should say input, or Internet. after that you will need another LAN wire (These look like telephone cables but the jack plug is larger and will only fit a lan connection on your router or computer) Connect the second wire to the line 1 or outout 1 from your router, to your pc in the slot where the other cable was connected. your internet signal should work.... on your mobil find any available network and log in to your belkin router.
that should do it.... if you haven't set up your internet connection, do that first by installing the drivers for the modem provided by your provider and then complete the process above.
Oct 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trouble expanding my Belkin Powerline network
F5D4075 uses Homeplug AV standard and F5D4071 used Home plug 1.0 Turbo. Both are not compatible to each other. So if you form a network, you have to form with the same standard.
Secondly, You need just one Powerline adapter on the router and you can have 2 or 3 adapter connected to 1 computer each and all these computers can connect to the 1 adapter on the router. You do not have to use it in pairs
Apr 25, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Netricity powerline ADSL2+ modem router
You most likely need to register the new modem with your Internet Service Provider.
Dec 27, 2008 | Computers & Internet
Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Aug 18, 2007 | Belkin (F5D7231UK4) Wireless Router
Belkin Powerline F5D4050 Network Adapter Logo
212 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
