Question about Hoover Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any ideas?
Hi i have the same washing machine, mine spins but leaks, i found this pump part number Part-No-H051HV have a look at eBay for the pump or http://cgi.ebay.com.au/Hoover-Maytag-Electric-Pump-Motor-Part-No-H051HV_W0QQitemZ310195337849QQcmdZViewItemQQptZAU_Home_Appliances?hash=item4839153a79#ht_2256wt_1162
i am about to buy one for myself, im no washing machine expert but just know things kind regards Stan h
Posted on Mar 17, 2010
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Posted on May 30, 2008
Hoover 500mb washing machine doesn't 'click' through the cycles
Sounds like your timer is not working correctly. I would suggest replacing it, as there isn't a way to repurchase timers.
Oct 10, 2015 | Hoover Washing Machines
Fitted new motor to a commander 7kg A6928 agitator spins but bowel stays still in spin setting why?
sounds like maybe a thrust bearing in the hub at bottom of agitator not engaging? are u saying the hub does not spin but the agitator moves?
Oct 31, 2014 | Hoover Washing Machines
The decals over the temperature buttons on my Hoover Commander 7kg washer have worn off....can I see a pic of the control panel
Methinks a manual would help you, for now and later!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 12, 2011 | Hoover Washing Machines
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
The 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Oct 08, 2008 | Hoover HTC243 Top Load Washer
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
510 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
