Question about Home
Looking for the stem unit diagram from delta for their single handle shower unit that uses the stem rp1991. in the info leaflet that comes with the replacement they refer to a spring. I want a diagram to help identify where this spring is located.
    Scholar:
  • 81 Answers
You can go to the link below to get a parts breakdown of your style of Delta. The seats and springs are recessed into the valve body behind the RP1991 stem. The flat part of the stem rotates back and forth across surface of the rubber seat, so in time the rubber surface wears flat and the spring can no longer push it firmly against the stem.and then the faucet drips.
http://www.plumbingpartsdepot.com/delta1600.pdf
Posted on Aug 06, 2010
I am trying to pry the plate off on my Delta Monitor shower faucet. It must be an older model and it is not the plastic handle but a smooth stainless steel handle. It has a plate on the front that will...
I believe the older ones were held on by center threaded on piece, after you remove the handle. It's threaded on behind the handle, round cover over stem. Turn counterclockwise to remove it, then plate should come off.
Oct 31, 2010 | Delta & Single Handle Shower Faucet
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
May 21, 2010 | Delta & Single Handle Shower Faucet
Delta single handle faucet leaks
BEHIND THE HANDLE THERE SHOULD BE A SET SCREW THAT HOLDS THE HANDLE ON THE STEM. THE SET SCREW WILL BE BEHIND THE LONGEST PART OF THE HANDLE LOOK AROUND BACK OF THE HANDLE. AFTER REMOVING THE HANDLA THERE WILL BE A STEM AND A NUT THAT HOLDS THE ASSEMBLY IN THE HOUSING
Sep 16, 2009 | Delta & Single Handle Shower Faucet
Shower push button shots water.
The valve needs to be rebuilt, replacing the washers and stems.
Aug 07, 2009 | Delta & Single Handle Shower Faucet
Replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
Apr 09, 2009 | Delta Monitor 13 Series Chrome Trim...
Home Logo
137 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
