My red comes out looking orange. what do I do?
  • dcidee Aug 04, 2010
    I have a RS-540 VersaArt
  • 906 Answers
We can only assist you if you could advise us what printer, model and type are you using.
Thank you.
Posted on Aug 04, 2010
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
I have a pioneer 6 Disc changer. Plug coming out of back has red wire black wire and orange wire.red is power black is ground. What is orange go to
Normally ORANGE IS the SWITCHED power +12 which must comes from the accessories circuit of the car. The Red is always connected to the +12 battery and is always ON.
Nov 12, 2011 | Pioneer Car Audio & Video
I need the value of resistor 45. It is discolored and looks like either red white red or orange white orange. I think the tolerence is silver but not sure. Thanks, ae4qp The unit comes on but has no...
150 ohm, 1/4W. But the problem is in STK 404-070 power amplifier. If you change only resistor, it will burn again. Try to replace power amplifier and then resistor.
Dec 28, 2010 | Yamaha YST-SW015 Subwoofer
1993 dodge shadow radio wire diagram i have a problem with my instrument lights on the dash board speed,gas,temp,gages lights will not come on the radio light is on and it plays and works good but i have...
Hello! I will assume you are connecting a factory radio for your 1993 Shadow.
Remove the Orange wire from ground...Listed below is wiring from car to radio; You may need this one day...You are correct; There isn't a dimmer wire...The Orange wire, from the radio, connects to the Orange/White of the vehicle...Grounding the Orange wire is causing your problem...
1993 Shadow...Orange/ White=Illumination...Red=Hot at all times...Red/White=Switched 12volts...Black=Ground
Factory radio...Orange=Illumination...Pink=Hot at all times... Red/White=Switched 12volts...Black=Gnd.
Car; Orange/White to Orange of radio
Red To Pink
Red/White To Red/White
Black To Black
Let me know how you make out..
Guru...............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 04, 2010 | Car Audio & Video
With my d90 reds come out as orange how do i stop
My guess is that it's not the camera but it's your monitor calibration. Reds (especially brightly lit reds) are the most difficult to render on a monitor. I would try changing the Vivid color option on the camera as well as saturation and even the color space options to see if you get any variation. Also, consider looking into a monitor calibration utility. If you have a color printer, you can print an image that looks orange on your monitor to see if it prints the same way.
Dec 24, 2009 | Nikon D90 Digital Camera with 18-200mm...
I have a rover75 when the engine running a red
Are you sure its red and not orange, if it is orange there will be a fault code, you now have 2 options you can either find some with with a fault code reader ie a garage (should charge about £30 to get your codes), or your other option is have a look on ebay for a obd fault code reader and do it yourself
Jul 07, 2009 | 2003 Renault 181
Maintenance required light is orange
it comes on after a certain amount of miles
look it over check all belts hoses brakes fluids
and check the timing belt if all looks good put your key in the slot next to orange light and it will goto green again if you don't reset it will goto red in a few miles but it is not the check eng. light just a reminder
Jun 28, 2009 | 1991 Honda Accord
Finepix s602z orange print
guess what, i have the imac G4, 10.3.9, 7960 printer and the 602, send me a picture I'll try printing it, and let you know.
Sep 04, 2005 | Fuji MX-600 Digital Camera
Open Questions:
ricoh aficio sp C232SF / c231sf When enabled, initializes but does not print Ricoh Aficio SP C232SF / c231sf The situation is. When enabled is initialized, writes that greeedy and is in readiness. No mechanism at this time does not work, except the scanner line. Scanning Starts, black and white is faster than the ruler, the color is slow. The document feeder works off a sheet and hands. After all the manipulations on the display Processig shines indefinitely no mechanism works until you press stop. The same situation when you try to print reports or when sending to print from a computer. the driver stood on the USB bus. Using command center see it all, but printing is also not achieved. Sees the tray and the presence of paper. Now this is the strange print though, and no, the black toner decreases. Already there was an inscription about it on the display and in commands the center shows the decrease in black. Only black. If you press for example copying, will stand and-writes about the heating of the stove no mechanical work and after a couple of seconds is ready. Stove at this time safely lying on the table next to the machine. the line Lamp is normal, but no power is supplied to it. The power supply did not find any problems. In the service you start the registration-work out the engines of development and tape, and a couple of auxiliary. Tried to make init EEPROMy, tried to rewrite the data in it, as if installing a new one-no changes Any ideas and assumptions are accepted And for dessert - a main Board, engine and the controller changed. The situation is quite similar. Sew and successfully both through the grid and through the USB port. I don't know where to look
Sep 23, 2018 | Ricoh Office Equipment & Supplies
15 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
