Question about Casio Exilim EX-S600 Digital Camera
Time set My camera will toggle between 12/24 hour time set ,but will not remain fixes in the 12 hr. position. Please help!
  • 374 Answers
Some of the cameras show that they have both but only will display in 24 hr. Check your manual for your particular version of camera to see which one yours has.
Posted on Sep 10, 2008
How can I change the date and time on my Fuji T200 camera, please
Use the MENU/OK button to the right of LCD screen in lower corner.
1. Press MENU/OK.
2. Press RIGHT side of selector to open Set Up MENU.
3. Toggle up/down to find the Date and Time setup.
4. Toggle with the selector to highlight year, month, day, hour etc
5. When each item is highlighted toggle up or down to find correct number.
6. When all are set press MENU/OK again to exit.
These instructions are on the manual which is on the CD that came with the camera.
Jul 01, 2011 | Fuji Cameras
My sony DSC-W130 had an E:91:01.. how will i repair it?
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Oct 19, 2010 | Sony Cyber-shot DSC-W130 Digital Camera
I HAVE A SONY CYBER SHOT DCS W210 WHIT ERROR E:91:01 IN DISPLAY TANK YOU hOLA TENGO UNA CAMARA SONY CYBER SHOT DCS W210 CON EL ERROR E:91:01 HAY ALGUNA FORMA DE SOLUCIONARLO? GRACIAS
Thank you !!
Aug 18, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
As soon as I turn it on, it shuts back off
Kodak offered no help with this problem and for my camera more than five years old no repair option was available. However, after thinking about this problem a solution was found. Perfectly charged old batteries and new batteries fully charged did not correct the problem. Here is what worked for me: With fully charged battery installed, place closed camera on EasyShare-One camera dock. With the the green light flashing, simultaneously depress both the power on/off button and the shutter button. With both these buttons held down, toggle the capture view switch from an intial down position to up, and then down position.Now release both the power on/off button and the shutter button simultaneously. This whole process takes about 20 seconds. Let the camera remain on the dock until the green light stops flashing. Remove the camera from the dock, open the camera back as usual and the screen will present you with date/time setup. Enter the date and time as required, hit the 'done' icon with the camera pen and the camera will now function normally. Why this works is speculative. However, the idea behind this method is to force a 'reboot' to factory settings by maximising conflicting electronic input signals.
Dr Barry T Rubin
Aug 13, 2010 | Kodak EasyShare One Digital Camera
Flashing E 91:01
Thank you !!
Jun 27, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Error:91:01 how do you get rid of it?
May 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
How to use flash on a vivitar vivicam 8690
Look on the Mode Dial find a small icon looks like a camera, rotate the Mode Dial to select.Toggle the flash settings. Look on the Mode Dial and find a small icon that looks like a camera, then rotate the Mode Dial to select this setting. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Mar 17, 2010 | Cameras
How do you change the Date Time Stamp in the GoPro Hero series of cameras?
Taken from manual:
SETTING THE TIME AND DATE
You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is
removed the time and date settings will be lost:
Symbol on LCD Screen Function
When you see "dAt" on the screen, press SHUTTER button to set the
time and date.
Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030).
Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 01 (January) to 12 (December).
Press POWER/MODE button to toggle from d01 (1st day of month) to d31
(31st day of month). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23
(11 p.m. military time). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59
minutes). Press SHUTTER to advance to next date setting.
1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance
for the settings menu.
EXITING THE SETTINGS MENU
When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
Dec 21, 2009 | GoPro Motorsports Hero GMHW50 Digital...
Recharging time??????????
Max 2to2.5 Hours
PLEASE VOTE FOR ME
Jun 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera remains on, with green light
i think i got a fix!!! tyere is a small opening next to the white toggle button,between >> arrows and below the /set .be careful and push a small object like the end of a tiny paper clip etc... this will reset the camera!!this worked!
Jul 01, 2007 | Polaroid izone 550W Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
Top Casio Cameras Experts
Fred Block
Fred Block
Are you a Casio Camera Expert? Answer questions, earn points and help others
