Question about Emerson LC195EMX 19 in. TV
Where can an owner's manual for an Emerson LC195EMX TV be found?
    Brigadier General:
  • 7,191 Answers
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Aug 04, 2010
  • Toolfool Aug 04, 2010
    Sweet! I Finally got it! It was downloading blank pages. Turns out it was a problem with the older version of Adobe Reader. The upgraded version made all the difference. Thanks, man I appreciate it.
    Tool Fool
2 Suggested Answers
SOURCE: need remote code for emerson LC195emx LCD TV
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
Posted on Jun 03, 2010
How do I connect Emerson 19" model LC195EMX to direct TV
USE THE HDMI PORT WITH A HDMI CABLE FROM THE REAR OF THE DIRECT TV BOX TO HDMI PORT ON TV SET THE ON YOUR REMOTE PRESS MENU SCROLL TO THE APPROPRIATE HDMI NUMBER .OR USE VIDEO AUDIO CABLE FROM DIRECT TV BOX CONNECT TO AV CONNECTIONS ON TV SET AND DO THE SAME BY HITTING MENU SCROLL TO AV THAT SHOULD DO THE TRICK....GOOD LUCK
Oct 13, 2014 | Emerson Televison & Video
Codigos de control ucr 3220 para tv LC195EMX
0478,0431,0449,0461. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 03, 2013 | Emerson LC195EMX 19 in. TV
Codigos de directv para tv emerson LC195EMX
0035,0033,0031,0039. Try these codes.For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Can I records from a LC195EMX TV
No you can't output the video signal from the LC195EMX's tuner to another device. It only has video inputs to obtain the signal from a DVD or Blu-ray player, for example. There are audio outputs to use with a sound system or headphones. Thus you could record the audio track, if you desired.
The manual for the LC195EMX is available from Emerson: http://www.emersonaudiovideo.com/support/download_tv.php?id=6 . You will need some sort of a set top box to record to a DVD/VCR recorder with either an analog tuner or no tuner. (OTA digital to analog converters connect easily to DVD recorders. For best signal, use a switch to feed the signal to the recorder, instead the TV. Splitters can be used to feed both at the same time. However, the signal loss could make either or both devices unwatchable with the digital OTA signal. Amplified splitters can reduce this issue; however, I've had the amplifier fail on several occasions. Then the amplifier blocks all of the signal or blocks select channel frequencies.)
I hope this helps.
Sep 27, 2013 | Emerson LC195EMX 19 in. TV
Great Picture but no sound. Help!
Check its speaker first. If it found OK, check and replace damaged component/s at the audio output section circuit.
Apr 24, 2013 | Emerson LC195EMX 19 in. TV
Emerson 20" LC195EMX remote code & retail
Hi , I just wanted to let the folks that have a emerson Lc195emx TV know that i have found no other universal remote that will work on this TV except very ironically Walmart's 5$ cheapest universal remote they have made by a company called ONN I tried LOTS expensive( LOL had to get refunds) & even my Comcast word not work , but this 5$ ONN from Walmart work like a charm there is TONS of codes for Emerson on the list , LOL i got lazy after tryin about ten and just used the auto search and in about 5 seconds it found my code and ohh my goodness i am so happy i just had to share :)
Jan 09, 2011 | Emerson Televison & Video
NOT SURE OF THE TYPE OF TV ITS A EMERSON HD
maybe theres a defect in your tv. maybe theres a shorted parts in the board. you need a qualified technician to fix your problem.
Jul 01, 2010 | Emerson LC195EMX 19 in. TV
Need remote code for emerson LC195emx LCD TV to program my uverse remote. ATT codes don't work. Thanks
Jan 21, 2010 | Emerson LD195EM8 19 in. LCD TV
Emerson LC195EMX 19 in. TV Logo
83 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
