Question about Sony Walkman TCD-D100 Personal Cassette Player
Sony TCD D100 - Chewing Tapes?
My TCD D100 after not being used for a few years has started chewing tapes, Sony has quoted me $500 to fix it. I can get a 2nd hand one for half that. If anyone has any suggestions re: fixing it cheaper, please let me know or email me at spin_orbit@hotmail.com
I'm hoping it's like a vcr and there might be a simple fix, i.e. rotation at wrong speed due to buildup from lack of use?
SOURCE: Sony Walkman TCD-D100
I have a faulty one as well, mine chews tapes, Sony has quoted me $500 to fix it. I can get a 2nd hand one for half that. If anyone has any suggestions re: fixing it cheaper, please email me at spin_orbit@hotmail.com
Posted on Apr 25, 2008
Philips VR550 chewing tapes.cannot reproduce fault
sounds like the take reel sensor is loose or going bad
Aug 17, 2009 | Televison & Video
Tape chewing
use a vcr cleaning tape.
Feb 18, 2009 | LG XBR446 DVD Recorder/VCR
Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Jan 18, 2009 | Technics RS-TR373 Single Cassette Deck
Distortion!
did you record them on the same unit?
It may be an alignment problem.
If it's the same unit, try cleaning the heads.
There are dat cleaning tapes too, but they beat on the heads.
Jul 31, 2008 | Sony Walkman TCD-D8 Personal Cassette...
Tape fails to return to cassette when cassette removed.
I'm an repairer of electronic and micromeccanaca I have repaired many walkman analog (WM-D6C, wm-dd9, etc.. Improve your performance if required and if possible) and many like dat walkman Sony TCD-D3. I just started to repair even for those who come out of Italy. If you would contact me to explain the problem better I'll try to help. Email: doctor.walkman@gmail.com Sono un riparatore di elettronica e micromeccanaca ho riparato analogico walkman molti (WM-D6C, WM-dd9, ecc. Migliorate le prestazioni, se richiesto e se possibile) e molti come dat walkman Sony TCD-D3. Ho appena iniziato a riparare anche per chi si trova fuori d'Italia. Se vuoi contattarmi per spiegare meglio il problema cercher? di aiutarti. Email: doctor.walkman@gmail.com
Jul 29, 2008 | Sony Walkman TCD-D100 Personal Cassette...
Tvcombi
You need to send it to a repair center because the problem might be a bad idle on the vcr deck player ,and you can not be able to fix it.Good luck.
Jul 25, 2008 | Televison & Video
Vidio tapes are chewing up
This is the number one failure mode for a tape machine.
One drive is used to pull the tape out and run it across the heads very accurately, and another drive is used to pull the tape back into the cassette. This one uses a clutch to allow it to slip so that the takeup reel in the cassette can vary in speed depending on how much tape is on it. After a few years, it slips too much and can't pull the tape in fast enough. (older units use rubber idler wheels to do the same thing)
Either tighten up the clutch, or replace the rubber wheel.
Hope Ya Fix It!
Feb 08, 2008 | GE 27GT616 27" TV
Picture is snowy and isn't clear
If you are using the RF out to connect to the VCR to your TV, perhaps the connecting Cable is faulty? And if you are connecting the VCR using the Audio Out / Video Out Cables, try replacing only the Video Out cable. In 95% of the cases, it is only the connecting cables which go faulty. If the above solution does not solve the problem, then we consider options. How old is the machine? if it is more than 5-6 years old, you need to get a service done. For chewing of tapes, 99% of the time it is a bad Pinch Roller(it is big (approx. 1 inch high. on the right side of the mechanism assy.)replace, and your chewing problem will go away.
Sep 29, 2007 | Sanyo VWM-900 VHS VCR
Apr 06, 2007 | Sony Walkman TCD-D100 Personal Cassette...
Chewing up mini-dv tapes
These type of problems usually result from damage to the tape transport mechanism, Unfortunately they are impossible to fully diagnose without a physical examination of the mechanism.
There is not a magic tweak for this i'm afraid.
Wish i could be more help
Jan 11, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Sony Walkman TCD-D100 Personal Cassette Player Logo
122 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
