Question about Akai LCT3285TA 32 in. LCD Television
Akai ct-2202 tv turns on but no picture when i connect cable tv wire, cable oprator said me your akai tv tuner problum Please solve my problum Sanjeev Kumar Delhi, India
    New Friend:
Sir . i need akai ct2202 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : srikum74@gmail.com pls help. thanks & regard's. V.SRIKUMAR
Posted on Jan 27, 2014
SOURCE: Akai leisure 2111 TV
I was doing some electrical work in my house, I disconnected all power source.
when I connected the power again, my picutre is not coming in at all on my akai 42 inch plasma.
it looks snowy, and jumps around theres adio but no picture what do i do?
Posted on Oct 18, 2008
  • 3 Answers
SOURCE: Akai television model CT-2107DT
Did you mean model LCT2701TD?
If so, you can find the repair manual at:
http://esi.fox-international.com/manuals/LCD%20TVs/LCT2701TD%20Service%20Manual.pdf
Posted on Jan 16, 2009
  • 6 Answers
SOURCE: AKAI PDP4206EA 42
I had the same problem... It's the main board. Unfortunately they're pretty scarce these days. You can try to get a Viore mainboard, but you're either have to make a 3.3v ttl serial cable, or desolder the flash from the akai board and put it on the viore board (the two tv's use different pdp's). The 1st option is a little less intense.
Posted on Jul 15, 2009
  • 6 Answers
SOURCE: AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
I'm pretty sure it's the main board. You'll need to get a new one. Hopefully you have better luck at finding one.
JE
Posted on Sep 30, 2009
  • 6 Answers
SOURCE: Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Akai projection tv has static in it but it goes in and out with the static sound and picture
If it does not do it via the rear audio and video jacks (a DVD etc) problem may be a bad tuner or even a bad connection on the cable wire or fitting at rear of set--move the cables at connection points with set on to see if a reaction.
If not from DVD etc there is a way around this issue.
Jun 13, 2012 | Akai PT5492S 54" Rear Projection...
My CT-32G6E Panasonic gives me no picture when I turn it on. It's clear that when I press the on-off switch (lost the remote years ago) that the TV does, in fact, come on. When I use the DVD player, it...
There are several defects that can cause that problem One .the tV tuner could be defective Two the processor IC might not be processing the tuner signal Three. the circuit that receives the signal when it leaves the processor IC have some shorted components.You would have explore all of those possabilities in an effort to solve your problem.
Mar 28, 2010 | Panasonic CT-32G6 32" TV
AKAI LCT2016 20" LCD TV- Dosn't Resize picture properly
U can't fix this problems.Omly replaced board.The Tuner main board have dead componnents.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for replacement.
Feb 20, 2010 | Akai LCT2016 20 in. LCD Television
Tuner connection broke
set tuner cap re solder with tuner fix this problum solve esyly but don,t fix it your self if your not tv.techician.becous it is a dengerus for you.
tv. tuner is not costly.
Nov 16, 2009 | RCA F25432 25" TV
Tuner problem?
This is an indication of a bad ground connection. Since you have replaced the cable and splitter, it suggests an internal grounding problem. If you can solder and can get to the tuner, resolder the ground points within the tuner and update this with the results.
Dan
Sep 30, 2008 | Panasonic CT-27E13 27" TV
AKAI TELEVISION
Probable bad tuner or tuner circuit issue, repair or bypass.....
If you can direct signal to A / V inputs as you are doing with your
DVD, then no repair is necessary.....utilyze cable box or VCR
tuner to change channels.......................T.
Dec 03, 2007 | Televison & Video
Picture on tv
check for a bad solder at the the tuner section or within the tuner . Bad solder ground within the tuner can cause this fault
Apr 21, 2007 | Panasonic CT-36D32 36" TV
Akai LCT3285TA 32 in. LCD Television Logo
119 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
