Question about SanDisk Sansa e260 MP3 Player
Recovery mode I know how to switch to recovery mode and all that but i cant find the files needed to install. I even went onto the sandisk website but the recovery files they had were corrupted......i just need some files someone please help.
  • ccbehrens Sep 27, 2008
    my model is e260 and it will not dowload music
    Problem Solver:
  • 5 Answers
Is the old model u got?
Cuz the new one, all you have to do is change format and that recover all you mp3.
Posted on Apr 27, 2008
Sansa e280 recovery mode
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | SanDisk Sansa e260 MP3 Player
Messed Up.
hi what you need to do is put the mp3 into recovery mode to do this follow these instructions
1 with mp3 player off push hold/lock button to lock position(this is what you press to stop you pressing buttons when its playing it locks the buttons out) switch this to lock
2 press and hold rec button on left hand side keep holding down
3 whilst holding rec switch mp3 player on keep holding rec button untill it comes on it should now say recovery mode.
Dont do this whilst plugged into computer and dont plug into computer after its in recovery mode untill told to
once its in recovery mode got sandisk website and download the latest firmware once you have downloaded it onto your computer then open the file on your computer it will then talk you through the rest of the procedure this will solve your problem.
Let me know how you get on or if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
hi follow these instructions ok
1 with mp3 player off switch lock/hold to on
2 press and hold down rec button on left hand side keep holding down
3 switch on whilst still holding down rec
4 it should now say recovery mode
dont do nothing just yet dont connect to computer ok first goto sandisk website and download the latest firmware once downloaded open the file and it will tell you how to install this onto mp3 player.
you should no longer have your problem
let me know how you get on and also if you need further assistance ok
Sansa mp3 player e200 version
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
I cant find the songs to delete and it the refresh database fails everytime
If you cant see it in MTP mode, the MTP drivers may not be installed on your computer.
Its easier to do this than explain the other solution.
Follow these instructions and you will be back in business.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Sansa media player 4gb
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 02, 2007 | SanDisk Sansa e250 MP3 Player
Just Died!!!!!!
Remove the card from the device. Put the device into recovery mode to verify that it still functions. Recovery mode - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button If it does go into recovery mode, its not dead. Slide the hold switch back over, then turn the device off. Try turning it back on, if it functions, great. If not, reply with the message, or problem and ill go from there. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
Load main failed switch to recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 07, 2007 | SanDisk Sansa e260 MP3 Player
Recovery mode
Recovery mode won't help you unless you have the recovery files to go with it. Most likely you will need to re-install the firmware on to the device. Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted. Tool is here; http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc) Hope this helps.
Sep 04, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
