Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Where can I find the specifications for Kenmore Elite Model 795 refrigerator? I have the user's manual and it's not in there.
5 Suggested Answers
  • 62 Answers
SOURCE: Fridge Area Light Will Not Turn Off
Yes unit was built by LG. The light broplrm is most likely the motherboard along with the light socket assembly that would have to be rreplaced. There is service information that the repair should be cover by an extened warranttee from the manufscture. The service flash sf46-515 indicates this and was recently put out. call Sears for service. Please note: recheck your model number as the one covered in the service info ends in the number :"one" insted of a "0"
Posted on Sep 06, 2008
  • 128 Answers
SOURCE: Refrigerator does not produce ice or water.
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Posted on Mar 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
repairman45
  • 130 Answers
SOURCE: I have a Kenmore Elite
this is caused by one of two problems. The foirst being the water valve will no longer open due to water deposits on the valve. This can very easily be replaced by pulling the unit out from the wall and removing the rear panel using a 1/4 inch socket. The second problem and cheaper of the two is to replace the switch that controls the water valve, both the parts you need can be ordered at Sears, using your model number. Here is a diagram of where the switch is and how it breaks down. Diagram
Posted on Dec 20, 2010
I have a Kenmore Elite 795 bottom refrigerator. I keep getting an error code r dh. I cycle the power & it goes away for approx. three days. looking for a proper fix
Defrost problem when the defrost process fails to reach the required temperature to properly de-ice the cooling coils.
http://www.searspartsdirect.com/refrigerator-repair/error-codes/kenmore-refrigerator-error-codes-for-795-bottom-freezer-models.html
When you cycle the power you reset the code and it takes a day or so for the unit to cycle the defrost. Suggest that you ensure that the vents are not blocked.
Hope this helps?
Nov 11, 2016 | Kenmore Refrigerators
I have a Kenmore Elite model number 795 - 7105 how do you change the temperature in the refrigerator to go up and down
Check this link out: http://www.manualslib.com/manual/85627/Kenmore-Elite-795-7105.html?page=18&term=temperature&selected=3
Oct 21, 2015 | Kenmore Refrigerators
What is the lifespan of a Kenmore Elite Model 795?
Free Kenmore Refrigerator User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kenmore > Kitchen Appliance Kenmore Products 1 - 50 of 357 - Kenmore Refrigerator User Manual.
Jul 19, 2015 | Kenmore Refrigerators
Have Kenmore elite 795 710 63010, need to replace Funnel assy but need to R & R the LCD/LED panel
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite-Parts/All-Products-Parts/ADW73149901/0046/795/Model-79571053010/0583/0161000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=F1003026&diagramPageId=00006
Oct 22, 2014 | Refrigerators
Need to know the exact height of the sears kenmore elite refrigerator model 52704100
You should be able to find it in the manual
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-59675532400/0583/0161000?modelNumber=59675532400&diagramPageId=&documentId=
Oct 10, 2014 | Kenmore Refrigerators
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
70 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
