Question about Nokia 6600
NO SIGNAL - Nokia 6600
    Master:
  • 329 Answers
Try to format the phone by pressing the following numbers in the given manner
*#7780#
---or--
hold the "green key"+" * key"+"number 3 key " while pressing power on button
Posted on Aug 04, 2010
06 H3 Hummer right turn signal goes on by itself can't turn off
Turn Signal Lamps
The FRT/TRN/HAZ/CRTSY/MIRR and REAR/TRN/HAZ fuses in the underhood fuse block supplies battery positive voltage to the body control module (BCM). When the turn signal switch is placed in either the left or right position, a signal is sent to the BCM to illuminate the desired turn signal lamps. The BCM has an internal flasher that sends an ON-OFF voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, a separate ground signal is sent to the BCM to activate and flash all turn signal lamps including both IPC turn indicators. The front and rear turn signals are grounded at G105, G350 and G340. The sound for the turn signal indicators is produced by the IPC.
DTC B0525 Left Turn Signal Circuit
• DTC B0527 Right Turn Signal Circuit Low
• DTC B0528 Right Turn Signal Circuit High
• DTC B0529 Right Turn Signal Circuit Open
DTC B0530 Right Turn Signal Circuit
• DTC B0532 Left Turn Signal Circuit Low
• DTC B0533 Left Turn Signal Circuit High
• DTC B0534 Left Turn Signal Circuit Open
Could be a switch problem , short to ground on the signal circuit to the BCM , BCM seeing a input that shouldn't be there etc....
I would have it checked for DTC'S diagnostic trouble codes .
Jun 10, 2017 | 2006 Hummer H3
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Feb 11, 2017 | Buick Cars & Trucks
Passenger side turn signal flashes faster but dont work even at day runing light, comes on when head lights are on, replace bulb and socket because was melted but stilldoes the same
Turn Signal Lamps
The turn signal lamps may only be activated with the ignition switch in RUN or BULB TEST position. The T/SIG fuse supplies ignition voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, the turn signal switch sends an ignition voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. When the turn signal switch receives the on-off signal it will send that signal to the following lamps on the LH or RH side:
The Rear Turn Lamp
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
Oct 11, 2015 | 2001 Pontiac Montana
No turning signals
Turn Signal Lamps
The turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL, CORN LPS Fuse. Battery voltage is then applied through the TURN SIGNAL, CORN LPS fuse circuit to the hazard warning switch. The hazard switch supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the body control module (BCM) . The front turn lamps are grounded at G101. The rear turn lamps are grounded at G301 and G302.
Turn Signal Lamps and/or Indicators Inoperative
  1. Turn the ignition switch to the ON position.
  2. Place the turn signal switch in the LH and RH on position.
Do the turn signals operate properly?
Go to Testing for Intermittent Conditions and Poor Connections yes
Go to Step 3 no
Are all of the turn signal lamps and indicators inoperative?
Go to Step 5 yes
Go to Step 4 no
Are only the turn signal indicators inoperative?
Go to Step 16 yes
Go to Step 9 no
5
Check the TURN SIGNALS CORN LPS fuse for an open.
Is the TURN SIGNALS CORN LPS fuse open?
Go to Step 25 yes
Go to Step 6 no
6
  1. Disconnect the hazard switch.
  2. Turn the ignition to the ON position, with the engine OFF.
  3. Connect a test lamp between the ignition positive 1 voltage circuit of the hazard switch and a good ground.
Does the test lamp illuminate?
Go to Step 7 yes
Go to Step 27 no
7
Connect a test lamp between the ignition 1 positive supply voltage circuit of the hazard switch and the ground circuit of the hazard switch .
Go to Step 8 yes
Go to Step 23 no
8
  1. Install a fused jumper between the ignition 1 positive voltage circuit of the hazard switch and the turn signal flasher signal circuit of the hazard switch.
  2. Place the turn signal switch in the RH on position and the LH on position.
Do the turn signal lamps illuminate?
Go to Step 17 yes
Go to Step 15 no
9
Is a front turn signal inoperative?
Go to Step 10 yes
Go to Step 13 no
10
  2. Disconnect the inoperative front turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative front turn signal lamp and a good ground.
  4. Place the turn signal switch in the appropriate ON position.
Does the test lamp flash ON and OFF?
Go to Step 14 yes
Go to Step 11 no
11
  1. Disconnect the body control module (BCM) connector.
  2. Connect a test lamp between ground and the front turn signal switch signal circuit of the BCM.
  3. Place the turn signal switch in the appropriate ON position.
Go to Step 12
Go to Step 22
12
Test for an open or for a high resistance in the supply voltage circuit of the inoperative front turn signal lamp. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 34
Go to Step 21
13
  2. Disconnect the inoperative rear turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal lamp and a good ground.
Go to Step 14
Go to Step 28
14
Connect a test lamp between the ground circuit of the inoperative turn signal lamp and supply voltage circuit of the inoperative turn signal lamp.
Go to Step 20
Go to Step 26
15
Test for an open or high resistance in the turn signal flasher signal circuit. Refer to Circuit Testing and Wiring Repairs .
Go to Step 34
Go to Step 18
16
  1. Turn OFF the ignition.
  2. Disconnect the instrument panel cluster (IPC).
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal indicator and the instrument panel cluster (IPC) ground circuit.
Go to Step 19
Go to Step 24
17
Inspect for poor connections at the harness connector of the hazard switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 30
18
Inspect for poor connections at the turn signal switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 29
19
Inspect for poor connections at the instrument panel cluster (IPC). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 31
20
Inspect for poor connections at the inoperative turn signal lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 32
Sep 05, 2015 | 2001 Oldsmobile Intrigue
My right front turn signal not working the bulbs are good and so is the fuse but I don't have fire going to them it's a 2010 chevy 2500hd
You don't have fire , never heard it called that before ! Battery voltage , power but never fire ! An open CTSY fuse located in the I/P fuse block will affect the operation of the right front turn signal only
Turn Signal/Hazard Lamps When the turn signal switch is placed in either the left or right position, a ground signal is completed from the turn signal switch to the BCM. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the BCM. The BCM then sends an ON-OFF voltage signal through the fuses to the appropriate turn signal and side repeater (export only) lamps or to all of the turn signal fuses for hazard operation. The driver door switch and passenger door switch also receive voltage from the BCM turn signal supply voltage circuits for the mirror turn signals. The door switches have no function or control of the mirror turn signals other than a pass through connection for the circuits. The audio chime is also activated when the turn signals are ON. The instrument panel cluster (IPC) receives the signals to activate the turn signal indicators over the GMLAN serial data system. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators.
Ground is applied at all times at G201 to the turn signal/multifunction switch. The turn signal lamps may only be activated with the ignition switch in the ON or START position. When the turn signal/multifunction switch is placed in either the TURN RIGHT or TURN LEFT position, ground is applied to the body control module (BCM) through either the right turn or left turn signal switch signal circuit. The BCM then applies a pulsating voltage to the front and rear turn signal lamps through their respective control circuits.
Jun 25, 2015 | Cars & Trucks
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
Oct 13, 2014 | 2013 Nissan Rogue
I need the list of codes for a 1994 corolla
1.6 GLi COROLLA
DTC NUMBER TROUBLE AREA 12 clip_image001.gifRPM signal 13 clip_image002.gifclip_image002.gifRPM signal 14 IGN signal 16 ECT Signal 21 Oxygen sensor signal 22 Water temperature signal 24 Intake air temperature sensor 25 Air / Fuel ratio lean 31 Vacuum sensor signal 41 Throttle sensor 42 Vehicle speed sensor 43 Starter signal 52 Knock sensor 51 Switch COND
Sep 29, 2014 | 1994 Toyota Corolla
Giving the code E.27
E27 Open Throttle Switch Signal here is a list of all codes E12 No Distributor Reference Signal E13 Oxygen Sensor Not Ready E14 Shorted Coolant Sensor E15 Open Coolant Sensor E16 Generator Voltage Out of Range E19 Shorted Fuel Pump Circuit E20 Open Fuel Pump Circuit E21 Shorted Throttle Position Sensor E22 Open Throttle Position Sensor E23 EST Signal Problem E24 Speed Sensor Circuit Problem E26 Shorted Throttle Switch Circuit E27 Open Throttle Switch Signal E30 ISC RPM Out Of Range E31 Shorted MAP Sensor Signal E32 Open MAP Sensor Signal E34 MAP Sensor Signal Out Of Range E37 Shorted MAT Sensor Signal E38 Open MAT Sensor Signal E39 VCC Engagement Problem E40 Power Steering Pressure Switch Signal E41 Cam Sensor Signal Problem E44 Oxygen Sensor Signal Lean E45 Oxygen Sensor Signal Rich E47 BCM to PCM/ECM Data Problem E48 EGR System Problem E52 PCM/ECM Memory Reset E53 Distributor Signal Interrupt E55 Closed Throttle Angle Out of Range E58 Pass Key Control Problem E60 Cruise - Not In Drive E61 Cruise - Vent Solenoid Problem E62 Cruise - Vacuum Solenoid Problem E63 Cruise - Set Speed vs Vehicle Speed E64 Cruise - Acceleration Too High E65 Cruise - Servo Position Signal Problem E66 Cruise - Engine RPM Too High E67 Cruise - Switch Shorted E68 Cruise - Command Problem E70 Intermittent TPS E71 Intermittent MAP E73 Intermittent Coolant Sensor E74 Intermittent MAT Sensor Signal E75 Intermittent VSS Signal E80 Fuel System Rich E85 Idle Throttle Angle Too High E90 Cruise - VCC Brake Switch Signal Problem E91 Cruise - PRNDL Switch Problem E92 Heated Windshield Request Problem E96 Torque Converter Overstress E97 P/N To D/R Engagement Problem E98 P/N To D/R ISC Engaged Problem E99 Cruise - Servo Apply Problem
Jul 31, 2013 | 1992 Cadillac DeVille
Left turn signal will not work
either wrong signal bulb or short in left turn signal wiring if both left signal lamps not working.if only one of left turn signal dont work could have corroded bulb socket spray a little electronic cleaner in bulb sockets see if left signal work.
Nov 27, 2011 | Cars & Trucks
No signal and theres signal
sounds like you need a new tuner replaced or the ssb(small signal board) inspected. The tuner recieves the cable signal and converts it into an intermidiate signal which in turn the ssb processes into audio and video signal.
Sep 09, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
Nokia 6600 Logo
59 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
