Question about Kenmore Refrigerators
I have a kenmore cold spot. The top freezer reaches the proper temp. the bottom compartment only reaches 70 degrees
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Aug 04, 2010
Kenmore #970-155320 how much cold it has...cant find it its for bed bug killing experiment....
Turned to their coldest setting, most properly functioning household refrigerators can attain minus 6 to minus 10 degrees in a normal (70-78 degrees) room. Room (ambient) temperature affects cooling performance. Colder temps will cause the unit to run significantly more.
Oct 28, 2016 | Kenmore Refrigerators
My kenmore top fridge bottom freezer in my cold garage is 22 degrees in the fridge and exploding soda cans
The temp setting for the freezer impacts that temp in the refrigerator. What is the temp setting? How cold is the room that it is in.
Feb 06, 2015 | Kenmore Refrigerators
The refrigerator compartment will not cool the freezer is still freezing top temp 70 bottom temp -10
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Amana ABB1927DES Stainless Steel Bottom...
I have a Kenmore bottom fridge model #596.69274991. Although things are cold and frozen, the room temp is only 70 degree but it seem to run for well over an hour although there has not been much opening...
Tom, you pretty much have it all covered. Make sure both the freezer fan and the fan under the fridge are both running and keep your eye on the inside back wall of the freezer compartment fro any signs of frost build up (possible defrost problem).
Jun 12, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Jan 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
