Question about GE (PSS26MSRSS) Side by Side Refrigerator
My model number is GSS25XGPC WW For a couple of days we have been hearing a chirpping sound in our regrigerator.
GE GTS17JBSBB makes chirping/tapping sound
thats not a fan noise. to me, sounds like pressure going thru an expansion valve. you better get on an appliance thread website with that one. meantime....loose mounting of condenser pipe or evaporator outlet???
Nov 19, 2013 | Refrigerators
I have a 2005 Honda Element. automatic. Lately I hear an almost bird type audio sound.. Chirping or tea kettle type sound. Both are very low in volume. I turned off radio and ventalaition fan. Turned
The only chirping sound I know of for sure, is when the distributor bearings are on the way out. You can eliminate this as a possiblity by startng the car, open the hood and satand in front of the vehicle. Distrbutor would be obvious.
Feb 28, 2013 | 2005 Honda Element
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
Recently bought a 2003 Chevy Malibu. Great car. A couple of days ago it started making a "chirping" sound when in the car and more of a light click when you're outside. It's under the hood but couldn't...
well the chirp sounds like a belt problem but the light click is usualy the lifters try using a higher grade of gas,and hope its not a berring going in the water pump.
May 21, 2010 | 2003 Chevrolet Malibu
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
Oct 06, 2009 | Televison & Video
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
CAN IT BE FIX?
Sounds like a bad horizontal transistor and flyback transformer . Do you know how to unsolder and or solder ? If so you might have a chance . If no the avg. to get repaired is around $90.00 to $130.00 so shop around as some shops will charge more . The parts you could buy your self for around $30.00 to 40.00 . Good luck and if you think you could fix let me know and see if i can get you part numbers .
Mar 15, 2008 | RCA 32V524T TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
GE (PSS26MSRSS) Side by Side Refrigerator Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
