Question about Dishwashers
Water not heating up / stops before ist should
    Problem Solver:
  • 13 Answers
This is due to the element being burnt out you need to replace cost around £25
Posted on Aug 04, 2010
Have a WIXXL 146 that ist heating water, no fault codes are showing in the lamps, machine otherwise fine. Is the easiest way a resistance check on the element?
Try a volt meter first, if you are getting voltage the next best thing is a clamp amp meter. Resistance will be probably less then 15 ohms (guesing). I have added a link for the manual.
Indesit WIXXL 146 Instruction Booklet
http://www.manuals365.com/swf/indesit/wixxl146-gb-hires.html?page=12
Mar 02, 2015 | Washing Machines
Why does my water heat keeps going out if a put a new thermo coupler
That guy at home depot was not completely correct. If the pilot is not keeping the thermocouple warm, the pilot will not stay lit. Figure out why the cycle is being broken or call in a service tech to fix the unit. water heater
Feb 15, 2015 | Water Water Heaters
Goodman a32-10
the fan is designed to come on with ist stage sequencer. you may have a bad heat strip and it is still heating
Feb 02, 2014 | Goodman Heating & Cooling
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Defrost, heater fan and air won't work on my 96
just a guess but being that the rear defrost is not woking id bet ist a fuse check owners manuel or go to a local autozone or the like store as thy should check this for free hope this is helpfull.
please post response good luck
Jan 07, 2010 | 1996 Saturn SL
I have a WP Gold GU1500XTLB. It will not dry the dishes. Any advice?
the heater may have failed or the thermo .. / low water tempt also causes poor drying . test the water tempt at tap you need 120 to 140 deg . and run water till ist hop before starting dw . set the dw for pot & pan or a cycle that uses heat . if you have hi tempt wash use this button . and hi tempt rinse if it has it . all of these should help mm
Dec 08, 2009 | Dishwashers
Ideal boiler no heat to radiators but hot water still working
check the divertor head and valve.
sounds like it ist adjusing from dhw to ch.
take head off(remove pi at back,or side pin) and push pin in valve when calling for ch,if it works then the head has gone.
Nov 19, 2009 | Honeywell Programmable Thermostat Heater
Ist GREEN LIGHT FLASHES BUT WONT FILL WITH WATER
I also had this problem, it was the automatic anti-flood device, the upper spray arm water pie was leaking into base off unit which operated the anti-flood device.
Hope this is of some use to you and others
ipip32
Jul 20, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
*IST DS autofocus
Try using another lens, if this solves the problem you have a lens problem. If not the camera is the problem.
Jul 03, 2009 | Pentax *ist D Digital Camera
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
