Question about Cell Phones
When i press my track ball it keeps writing qeqeqeqeqeqe help?
    Master:
  • Cell Phones Master
  • 329 Answers
Clean your keypad.contact a technician
Posted on Aug 04, 2010
My blackberry pearl wont delete multiple messages at one time
There's an up button. Keep it pressed and scroll with the clitter/track ball.
Feb 06, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
My side kick lx track ball is messed
this can be and is usually caused by dirt or sweat in the track ball that has caused damage to the phone the only cure i can think of besides returning the phone for a new one or taking it to a cellular repair store is to open the phone and try to clean out the area by and around the track ball keep in mind you risk further damaging the phone if u take this path
Aug 22, 2009 | Sharp Cell Phones
Tracking ball not working after cleaning it exactly as directed
do a battery pull.. wait 30 to 60 seconds, the reboot up you blackberry, and firmly press down on the tracking ball as you scroll up
Jun 11, 2009 | RIM BlackBerry Pearl 8100
The window keep sliding down. What should I check first. Do the window motor need to be replaced?
I have had two Roadmaster Wagons (we love 'em) with the same problem. The problem I found was only in a plastic clip that the actuator arms snaps into. I have not found an easy solution to replace, but it can be done. Take off the door panel and lower the window some (with help of a friend) so you can see the track at the bottom of the window. In that track there are plastic clips with a socket that a ball from the actuator arms snap into. You will probably see that one (or both of those) is broken. You need to slide out the old clip (you will need to bend out the indentation on the metal track so you can get it out) and slide in a new clip from a salvage yard. Now the hard part is pressing the ball from the actuator arm back into the socket of the new clip. I found I needed a special pair of pliers that opened wide enough without requiring the handle to open too far. After it is snapped back in, you should be ready to put the door panel back on and hit the road.
Apr 28, 2009 | Buick Roadmaster Cars & Trucks
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
Ghb middle marble
Check the settings in the bios to enable the track ball. Most of the time that is where it is enabled or disabled. You can also check Dell's support website for additional software that may allow you to configure additional settings (similar to IBM/Lenovo Thinkpads).
I don't recall the specific key to press to get into the bios, its either F1, F2, F10. You need to do this from a cold start when the laptop is off. Press the power button and when you see the Dell logo, look for the bios settings key to press or press one of them that I suggested. Sometimes this may go by quick so you need to be quick about it as well.
Hope this helps!
Oct 17, 2008 | Dell Latitude C600 Notebook
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl
First, turn off the device. While pressing down firmly on the track ball roll the ball in all directions.
If that doesn't work, then you may need to take out the track ball and blow it out with compressed air. The link below shows how to disassemble the track ball:
Oct 01, 2008 | RIM BlackBerry 8700c Cellular Phone
Roller ball keeps bringing up the letter q when pressed
thats happening to me to and when i try to write a text message the letter q or w is attached to every letter i type! please help ME!!!!!!
Jul 11, 2008 | RIM BlackBerry Pearl 8100
Kenwood ddx-6019 password
a friend of mine who is into bypassing stuff...found this method from sumwhere and it worked on my system...
u need to reset the system first by pressing the small button right next to <ATT> using a ball point pen or something pointed... once it reboots, keep the <SRC> button pressed till the display goes off, then while keeping the <SRC> button pressed, press the <ATT> button for 3 seconds, while keeping both of these pressed at the same time, press the small <RESET> button next to the <ATT> button using something sharp... this hard resets the system and it reboots to a blank screen, press the <SRC> button once and you have all the options working...
anything else, lemme know... varshik89@hotmail.com
Dec 02, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
