Question about Garden
Hi i have a draper bandsaw stock no 65699 pt no bs231 and it has torn up the drive gear situated on the end of the motor. this gear is made of plastic and the teeth fill up with saw dust making the belt jump the gear and recks the teeth on both the belt and gear. is there a replacement gear availaible or a modified gear to rectify the problem regards paul
fellowesrep
  • 102 Answers
SOURCE: Broken Plastic Gear Wheels
Check out this website if you have an outdated machine without a parts program still in place it may come in handy.
http://www.rushgears.com
Posted on Feb 25, 2008
  • 329 Answers
SOURCE: Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Posted on Jun 24, 2008
  • 3 Answers
SOURCE: NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
Posted on Jun 04, 2009
  • 32 Answers
SOURCE: I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Posted on Aug 31, 2009
SOURCE: First plastic gear driven from motor pinion has
I have a simple solution if you can think outside of the box. When my gear stripped, I chucked away the electrics, and now drive the shredder via a crank handle on the side. It gives good excercise, and isn't difficult to turn with anything up to 6 or so sheets.
If you want to do this, open the machine, and remove the smaller gear at the opposite end of the drive (take off the circlip) to expose a hex shaped shaft. You can also chuck all of the electrics, and all but the two gears that are on the shredder shafts. Then cut a hole through both the top casing, and through the bucket, to line up with the shaft end and allow a 9/16 socket to pass through. When reassembled, there is sufficient room to drive the mechanism with a standard 3/8 drive ratchet, although you could make a fancier drive with a handle on.
Happy Days
Garry
Posted on Jul 01, 2010
03 pt cruiser makes rattling noise when put in drive
does it make the noise and goes away within 5 to 10 seconds then it drives and shift fine let me know ok
Nov 27, 2012 | 2003 Chrysler PT Cruiser
I have a stock #414457 Jet bandsaw and when I try to tighten up the vise, it jumps back before it's tight. I think the problem is with the
If you need parts for your band saw, you can visit www.bandsawparts.com . They offer cheap aftermarket parts of Jet band saws.
Nov 08, 2012 | Jet 414459 HVBS - 7MW Horizontal/Vertical...
How to change the motor on a tefal actifry?
Bought a motor and drive shaft from Amazon plus a Draper security bit set (stock no. 38716 ( neither item expensive). Unscrew 3 security screws on bottom, separates easily, then motor and shaft readily replaced. Done in 20 mins.
Aug 20, 2012 | Tefal ActiFry Deep Fryer
How long to charge my Draper 6V rechargeable battery stock No.55950?
Should recharge in six hours or so, I don't advise leaving it charging more than 18 hours.
Aug 18, 2012 | Tools & Hardware - Others
Hi, I am English but have retired to Spain....However when I came over to Spain I brought over all my tools which I use for my hobbies. I have a number of Draper tools and find them some of the best on...
Draper Multi-Tool Stock Number 62727 Part No PT95K coupling repair replace.
I came up with a home fix for this issue since it seems this little Draper part isn't available anywhere in the universe - simply use a short piece of neoprene tubing as a connector or coupling.
As long as the tubing wall is thick enough (thin walls might flex too much), and the inner hole is small enough to fit snugly on those two end shafts, it should work fine. Anyhow, if the tubing does break or tear or start to slip, or whatever, just use another piece of tube.
My tubing was 13mm outer diameter and the wall thickness was 2mm. So an inner hole diameter of 9mm.
Make sure when you cut your tubing you account for it having to extend as far as it can go - it actually fits right down into the outer ridge. See my arrows on the one pic, if you're not sure what I mean.
PS. If you're lucky enough to be able to order on eBay, check out the Dremel shaft coupling part - it seems as though it might work here, too. Just cut it down to size.
All I did was:
1) cut my piece of tube and drop it into boiling water for a few seconds to soften it.
2) Take it out and quickly fit (force) it onto the end of the chuck side shaft. I chose that shaft as it's loose and I could fit the tube properly, plus I need to dip the tubing in the boiling water again and you can't do that if you've used the motor side first.
3) Dip the tubing in the boiling water again for a few seconds. Don't go too deep as you have a bearing there.
4) Lift the motor out slightly and force the tubing over the end, making sure it's seated right down.
5) Drop the entire joined up shaft into its place and put the side of the machine back in place for a few minutes. This makes sure the shafts are aligned while the tubing cools and hopefully shrinks a bit onto the two ends.
6) Open the side cover and check it's all good. Close up and away you go.
Sep 15, 2011 | Garden
Bandsaw tire part #41815, where to buy?
A bandsaw tire is usalley defined by the size of the saw. A example is a 12" x 80" bandsaw means that the wheel (tire) is 12" and the blade is 80" . If you are unsure just measure the wheel size.
Then go online and type in (example) 12" bandsaw tires.
You will soon see that there are a few different choices in material , the stock ones from sears are cheap but will do the job. Then there are the poly orange ones that cost more but don't slip like the stock ones.
Also type in bandsaw tires on YouTube this may help because changing them can be a pain.
Hope this helped, I asked the same questions when I got my first Saw years ago and am glad to pass it on. If this helped I would apperciate a comment.
Thanks,
Shop Dog
Feb 17, 2011 | Craftsman Saws
Replace belt
Sourced the part no and stock number on the Draper site, then sourced the Manual on the Draper site too
Nov 17, 2009 | Drills
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
