I just purchased a new Vivitek D510 and when I plugged it in there are vertical lines spaced evenly across the screen. They are there in every input and with just the home screen. What causes this and what should I do?
  • 57 Answers
Take it back, sir. Immediately.
Posted on Aug 15, 2010
The lamp turns on for a second and you can see the vivitek logo on the screen then it goes dark
some projector are normal like what what you mention...you need to connect a video source like computer or sound system that have a video output going to your projector...because if you power on the projector with out a video source you see only what you mention the logo of the projector..
Mar 10, 2011 | Vivitek D510 Projector
Vertical Lines
Hi I can try soling your problems
Feb 22, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
I am needing to verify if this projector allows for a widescreen image and what type of bulb does it use?
hi,
vivitek D510 supports 16:9 ( wide screen) format also. it uses 180w projector lamp.
ok
Dec 27, 2010 | Vivitek D510 Projector
Vertical lines half way across screen.
Try performing a factory reset of the TV2_bing.gif. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. If that does not work, send it back for repair. Good luck!
Jan 12, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Samsung WS32Z429T
This looks like it could be a problem with leakage of the 60Hz vertical scan frequency into the picture this is also called 60Hz hum. What usually causes this is poor filtering on the power supply or decoupling capcitors in the vertical section have begun to malfunction. This problem is easy to fix if you have the equipment to isolate the problem, I would suggest that you take this set to a TV repair shop to have it analyzed and repaired.
Sep 22, 2007 | Samsung WS32Z308P 32" TV
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
240 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
