Question about Bugaboo Cameleon - Tailored Fabric Standard Stroller
My bugaboo cameleon seat belt is too small. its tight around my 5 month old's tummy and doesn't seem to offer any extension. what do i do?
Whitenoize
  • 11 Answers
SOURCE: lost the bugaboo cameleon manual - need to install seat
You can find the user guides on the Bugaboo website.
https://www.bugaboo.com/US/en_US/support/product-information-strollers
Posted on Mar 23, 2009
  • 12 Answers
SOURCE: changing my bugaboo cameleon from carry cot to buggy
Watch the video, "bugaboo assembly" on youtube. The trick is getting the buckle over the silver pins. You actually have to bend the frame to secure the strap then pull out the frame so it is straight again.
Posted on May 12, 2009
  • 10865 Answers
SOURCE: Can I use the cameleon or frog seat frame on a gecko chasis?
Hello. My recommendation is to have your local tailor or seamstress make a new one using the old one as a pattern. Getting into replacing the seat frame will be a lot more complicated
Posted on Jul 02, 2009
  • 274 Answers
SOURCE: Bugaboo cameleon chasis not locking into place,
there is one company www.buggypitstop.co.uk that do repairs to bugaboo
Posted on Dec 07, 2009
macnutz
  • 541 Answers
SOURCE: Cameleon Jogger Stroller: The hinge on my bugaboo cameleon is stuck-in and n...
How to fix a Bugaboo Handle
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me!
1/. Remove the domed star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to prize off.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to ether repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. (I use a small amount of the grease used for taps to give a smooth action) If all has well fit, the new star dome on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern.
4/. Repeat operation on the other side. Note the disks are mirror images of each other and are not interchangeable. Bugaboo calls the side with the brake lever “LEFT” the disk will have a serial number that ends with “L”. I have had metal disks laser cut and stainless steel pins fitted. Cost of a disk with a new star dome washer is $75 New Zealand. If you like one or a set, you can contact me macnutz@xnet.co.nz
Regards
Steve
Posted on Aug 01, 2010
Tip
How to Assemble you Frog or Cameleon
Take care at step 3. A lot of people fit the small front wheel incorrectly and it's not easy to get them back out! See image (G) for a better view.macnutz_10.jpgmacnutz_11.jpg
The Bassinet is only suitable to six months old according to Bugaboo but Baby usually wants out sooner and will let you know! macnutz_12.jpgmacnutz_13.jpgmacnutz_16.jpgmacnutz_15.jpgmacnutz_17.jpgmacnutz_18.jpgmacnutz_19.jpg
on May 05, 2011 | Bugaboo Cameleon Jogger
I have a bugaboo cameleon 1st generation that has a fault. If i was to buy a new 2nd edition chassis would my carrycot still fix on to this chassis.
I have a second hand chameleon and it feels like the frame is a little loose. Is there any way that you could tighten the frame up?
May 10, 2011 | Bugaboo 'Cameleon' Stroller
I have a bugaboo wlth the white colour brake and have just found out that the white colour ones are out of date. my question is does anybody know if i can get it changed over to the red one and how much...
Bugaboo don't sell parts as such but they sell the chassis. It will coat you around a third of the price of a new Bugaboo. The new Red brake lever chassis has the lever extension handle locks instead of the wing-nuts and rocker style buttons for the handle release. Your old frame will be quite sort after on eBay. I like the rocker handle release and the extension levers are quick to use and look better but I must warn you the old wing-nut system held the handle better and if you bump down a lot of stairs the new lever system is more prone to slipping, macnutz_16.jpg
Nov 21, 2010 | Bugaboo Cameleon Jogger
My Bugaboo seat will not lock in any position : ie reclined, flat or straight up. It seems the circular locking mechanisms will not pop out into locked position
I had the same problem with my 3 year old frog. I called bugaboo customer service and they sent me the parts & instructions to fix it at no cost
Sep 23, 2010 | Bugaboo Cameleon Stroller
I have a bugaboo chamelon pram , the two round white knobs at the side for reclining seem to be stuck and wont click back into place !! making the carrycot?pushchair unstable
If the Cameleon is under two years old then it is covered by the warranty. The best thing to do is to contact the retailer you purchased the pushchair from or contact Bugaboo direct (www.bugaboo.com). They should arrange for a set of replacement buttons for the seat frame and instructions to be sent to you. If it is out of warranty, you'll just need to purchase these spare parts from them.
Sep 15, 2009 | Bugaboo Cameleon Jogger
Maxi cosi mico car seat on bugaboo is not level with the ground!
you may have put the car seat brakets the wrong way round change them around and try again or go to www.buggypitstop.co.uk they are experts on bugaboos
Jul 14, 2009 | Maxi-Cosi Mico Infant Car Seat
HIYA.... IVE HAD ALOT OF BUGGIES AND PRAMS... IVE ALSO MADE MANY BUGABOOS UP, JUST BY USING USED PARTS AND PIECING THEM TOGETHER.
ALL COMPONENTS FROG, CAMELEON AND GECKO FIT ONTO 1 AND ANOTHER. YOU COULD BUY A FROG SEAT FABRIC TRY EBAY FOR THE CHEAPER OPTION, THIS IS EXACTLY THE SAME SIZE. THE CAMELEON 1 WOULD ALSO FIT, AS IVE HAD A CAMELEON COVER ON A FROG SEAT FRAME AND IT FITTED JUST AS GOOD :)
HOPE THIS HELPS X
Jul 02, 2009 | Bugaboo Gecko Stroller
Lost the bugaboo cameleon manual - need to install seat
Mar 23, 2009 | Bugaboo Cameleon Jogger
Bugaboo Cameleon - Tailored Fabric Standard Stroller Logo
129 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
