Question about 3Com NBX® V3000 (3C10600BUS)
I cant modify an extention number the apply button is greyed out
  • 58 Answers
If you are using Internet explorer 8 click on the compatability mode icon. That should do it. You can also click "OK". I'v seen some strange things with IE 8 and the NBX Netset interface.
Posted on Aug 09, 2010
Tip
Protecting your documents with password !!
You can protect your document by applying password so that unauthorized person can not display as well as modify your document. You can apply two types of passwords:
Password to open the document:
If it is applied then you have to give the correct password to open the document, otherwise you cannot open the document.
Password to modify the document:
If it is applied then you have to give the correct password to modify the document, otherwise your document is opened but you cannot modify the document. It means that your document becomes read-only.
To apply a password to document, follow these steps.
* Open Save As dialog box by selecting "Save As" command from File menu.
* Click "Tools" button of Save As dialog box and choose "General Options" from drop down menu, "Save" dialog box appears as shown in figure below.
* Enter first password in "Password to open" text box and second password in "Password to modify" text box (if required) and click "Ok" button of dialog box. Microsoft Word will open "Confirm Password" dialog box for the confirmation of passwords. The maximum length of password is 15 characters.
* Re-enter the password to open and password to modify and click "Ok" button of Confirm Password dialog boxes one by one.
* Click "Save" button of Save As dialog box.
on Mar 19, 2010 | Computers & Internet
Tip
Protecting Document with Password
on Jan 29, 2010 | Computers & Internet
Lost password and i cant use my ipohne with router.
Modify the router's settings.
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing www.fixya.com and kindly rate this post.
Jan 03, 2012 | Linksys WRT110 Wireless Router
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Tip
How to protect MS Excel file using password?
In Microsoft Excel, you can protect a single cell, group of cells on a worksheet or an entire workbook by applying password so that unauthorized person can not display as well as modify your document. You can apply two types of password.
If it is applied then you have to give the correct password to open the workbook. Otherwise you cannot open the workbook.
If it is applied then you have to give the correct password to modify the workbook. Otherwise your workbook is opened but you cannot modify the workbook. It means that your workbook becomes read-only.
To apply a password to MS Excel document, follow the given steps:
First click on "Tools" menu and select the "Option" from drop down menu.
A windows dialog box will appear, here select the "Security" tab.
Enter first password in "Password to open" text box under "File encryption settings for this workbook" section and second password in "Password to modify" text box (if required) under" File sharing settings for the workbook" section then click "Ok" button of dialog box.
Microsoft Excel will open "Confirm Password" dialog box for the confirmation of passwords. The maximum length of password is 15 characters.
Now close the file and then reopen to test the password.
on Dec 03, 2009 | Computers & Internet
I have officejet pro L7500, and i cant send a fax
put two pauses after the phone number then the extension
Jul 04, 2009 | Office Equipment & Supplies
Cant hit an extention number or option number on voice mail.
once in call there an arrow i beleive it will bring up the keypad, speaker and mute. i think its a arrow or there is an icon once you call jsut try any of them there. i dont have my phone handy with me right now.
Apr 07, 2009 | Dual Electronics CECT P168 Cellular Phone
Cant unlock
Try removing the batteries, wait for a while ,reinsert batteries and reconnect to reciever. Let me know how it goes..
Sep 10, 2008 | Logitech Cordless TrackMan Optical...
Desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
3Com NBX® V3000 (3C10600BUS) Logo
80 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
