Question about Audiovox 2-Way 14 channel FRS Family Radio Walkie Talkie 2 Mile Radios
I get a skweeel whin I try to talk. I tryed a new set of batteries (no help) Bill Kasley
  • 677 Answers
Hi, squeaky sounds a likely caused by bulged capacitor inside the radio or the internal speaker.
If otherwise transmitted is faulty,this will require a skill personnel to handle it, cause it will need opening the transmitter for troubleshooting to detect the faulty component inside the transmitter.
Take care.
Posted on Aug 04, 2010
My Straight Talk Huawei says it has no service but was working last night and now just wont send messages what is going on
1. Did you pay the bill? Check with them, maybe your service got cut off.
2. If it isn't #1, Take the SIM card out and put it back again, maybe the SIM card is faulty.
3. If possible, go to settings, mobile network, and choose to search for your wireless carrier, once it pop up, tap it to register.
4. You also must make sure your APN is in order. And have the correct APN check for Straight Talk.
Oct 10, 2014 | Straight Talk Huawei Ascend Y Cell Phone
How to get the whinning noise outta my radio in a f-150
Try running the ground wire directly to the battery ground.
Aug 07, 2014 | Planet Audio Peq15 5-band Parametric...
HELP!! my nokia 6500s wont allow me to get on the menu screen,, whenever it starts up,, it shows Push to talk,, and it wont go away,, ive restarted it several times,, it still shows push to talk,, push to...
Try doing this. Turn off the unit, remove the battery, press and hold the power button (while battery is out), then put the battery back and turn it back on. If that doesn't work, just repeat the steps including removing the Sim Card. Or turn on the unit without a Sim Card.
You can also try using reset codes but that would reset EveryThing back to default settings which might include losing the settings of your provider which is not recommended. But the initial step is safe to use.
Hope this helps.
Nov 16, 2010 | Nokia 6500 Slide Cellular Phone
WHIN TURNING ON BOTH LIGHTS START FLASHING AND WILL NOT DO ANYTHING IS THERE A WAY TO RE SET WHITH CONTROLS . WE PUT NEW BATTERIES IN DID NOOT HELP.
The chair might be in lockout mode. Check the owners manual to see if they tell you how to get it out of lockout. Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
I have a pair of FR60 Talkabouts. I have not used them in a few years. After putting in fresh batteries, one is fine. The other is indicating "low battery" by the red flashing light next to the...
There's a good chance that your problem is due to corrosion buildup on the radio's battery contacts. Even if you can't see and buildup, wipe the contacts firmly with dry cloth, the reinsert the batteries and try the set again. If you can see a heavy buildup on the contacts, you may need to clean them with a fine wire brush, steel wool, or fine sandpaper. Be sure to remove any residue from the cleaning before you install the batteries.
Bill B
Aug 07, 2010 | Motorola Talkabout FR60 (14 Channels)...
WHEN YOU KEY THE MIKE ALL IT WILL DO IS SQUEEEL. CHANGED THE BATTS. Bill Kasley
Hi, it's usually caused by either the speaker or the ball capacitor that controlls the sound from the hard way.
If you can replca your self,please contact a skilled personnel for help.
Take care.
Aug 04, 2010 | Audiovox Audio Players & Recorders
Whinning noise when talking
The antenna could be at fault causing feedback into the radio. check with a good SWR meter to confirm this. Also check the power lead to the radio, try to connect directly to the battery.....
Feb 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
My lg viewty ku990 says inactive usim whats that mean can i fix it
the sim card is located behind the battery, the contacts could be dirty from being in your pocket, your service is over with your current cell bill, or you have to talk with your current service provider and they can offer you a new sim card or try to reconnect you.
Jan 03, 2010 | LG KU990 Viewty
When I try to make a call I get a message that
you both are wrong because i have a brand new sim card and i pay my bill and it is still happening to me.
Oct 01, 2009 | Samsung Eternity Cell Phone
Audiovox 2-Way 14 channel FRS Family Radio Walkie Talkie 2 Mile Radios Logo
16 people viewed this question
Top Audiovox Radio Communications Experts
eradiostore
eradiostore
john milligan
Thomas Perkins
Thomas Perkins
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
