Question about Sony Ericsson W200i Cellular Phone
How to flash this model - Sony Ericsson W200i Cellular Phone
    President:
  • 1,912 Answers
You can use the Unlock code to Flash the Mobile from the Network Lock...You can get the Unlock code here http://www.wickedunlock.com/sony-ericsson-w200i/rs11wp9/
and Unlock it....
Posted on Dec 22, 2010
  • 624 Answers
Hello and Welcome to FixYa!
If you are referring to Firmware update / Software update also know as flashing the phone, then I can guide you.
You can easily flash your W200i with the help of the update utility provided by Sony Ericsson itself, its easy to use all you need is the USB Data Cable without it, its impossible.
If you have it, just download the update utility from the link I've provided below, you can also read all the necessary information about this Flashing procedure there, I'll advice you to see the before you begin section there also.
In Case you are having issues/problems/questions, don't hesitate to ask, We are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Updating the Firmware (W200i Flashing)
Posted on Aug 04, 2010
My flash drive does not work in my 2014 dodge durango
It could be the model of flash drive you are attempting to use. Check and make sure the car accepts the flash drive type. Some flash drives are high data transfer and will not work. Try another type/model drive. I've had this happen before and had to use an older flash drive.
Nov 21, 2014 | 2014 Dodge Durango
In side flash not working
Unless your camera remains under warranty, repairing the flash is usually not cost-effective. Repair is not a DIY option and it must be done professionally. If you visit the Olympus website in your country and go to the service page you will often find that there is a fixed price repair menu on offer.
You may find it's cheaper to fit an external flash to the external hotshoe especially if you can buy a good used flash, but you must ensure that you either use an Olympus or Panasonic model; you may use other independent makes such as SunPak or Metz (expensive, but really worth it) but must ensure that they're suitable for digital cameras. Older flashguns designed for 35mm film cameras can pass too much voltage through your digital camera and damage it. You may also need to activate the external flash hotshoe via the menu as on most cameras it's inactive until selected. Note that an Olympus/Panasonic badged unit will give you full automatic operation, but if you use independent models then you will have to set everything yourself for "non-dedicated" models, and on more expensive "dedicated" models you may have fully automatic operation or may have to enter some settings manually. "Dedicated" flashes are those which have electronics and features tailored to particular camera brands.
Although an external flash is bulkier, the trade-off is that even lowly specified models will far exceed the output of your built-in flash. This enables you to use flash at greater distances and also provides more even illumination of the subject.
Sep 29, 2010 | Olympus SP-350 Digital Camera
Quantaray QTB-9500A with Canon Xsi not working properly
This is probably way too late for the original asker, but the previous answer is incorrect.
The Quantaray QTB-9500A is in reality a ProMaster FTD-5700 and was designed for use with later model electronic 35mm AF models (using the correct dedication module).
As such, the trigger voltage is no higher than 5v making it safe for use on later digital SLR's.
The original answerer is clearly aware that high trigger voltages on flashes designed for earlier, mostly mechanical, 35mm film cameras are often harmful to later models, but you need not worry about your model.
Please take a moment to rate my answer.
Aug 30, 2009 | Quantaray QTB-9500A TTL Flash
The television will not turn on. Initially, when the remote (or button on tv) was used you would hear it turn on and hear some volume and then it would turn itself off. A red light would flash, stop...
You did not specify the brand and model of your tv but based on experience the red light indicator flashing means a projection lamp problem. Check the lamp and lamp doors if properly secured. If symptom persist you need to replace the lamp.
Aug 10, 2009 | Televison & Video
Flash
Each make/model may be a little different but if your model has a button to raise the flash, you need to open/raise the flash. If your camera's flah is already visable, make sure the setting for flash (symbol of lightning bolt) is set on Auto
Jun 23, 2009 | Cameras
Quantum Flash Repair
Check voltage at cable of Turbo, should be over 245V.
May 30, 2009 | Quantum Q Flash T5dR Digital Flash Head...
How do I turn my flash off on my samsung digimax 4010
You don't say which model Digimax you have. Hopefully this will cover most models.
First, make sure the menu is not being displayed on the LCD monitor, otherwise you'll just move around in the menu screen. You must also be in photo record mode, ready to take a picture (not in playback or movie mode).
There is a button (usually on the left side of the direction pad) that looks like a lightning bolt. I can't remember the exact number of times you must press it, but the display should indicate that the flash is turned off as one of the options as you cycle through them.
Depending on your model, the modes are likely to be Auto Flash (bolt with an "A" icon), Auto with Red-eye reduction ("eye" icon), fill flash - always on ("bolt" icon), Slow sync (bolt with an "S" icon), and flash off (bold with a line through it icon).
Also depending on your model, you may not be able to turn the flash off depending on which recording mode you're in. For instance, you can't turn the flash off if you're in the "Backlight" recording mode.
Dec 13, 2007 | Cameras
Help
I hope that you've said the wrong model.
The right model is DSC-R1 with 24-120 Carl Zeiss' Japan.
Buy the Metz 54MZ with adapter for Minolta/Sony.
atdlee@netzero.com
Nov 13, 2007 | Vivitar 840AF AutoFocus Zoom Electronic...
Vivitar 283 charges but fails to flash
I had the same problem with my early Vivitar 283 flash.  I discovered that the thyristor on the trigger board tested as an open circuit.
Trying to find a replacement for a 30 year old thyristor semi-conductor proved to be fruitless.
My solution was to purchase a broken, late model Japanese 283 flash off of ebay and transfer the trigger board to my early Japanese model. The late model thyristors could handle more heat.
Problem solved.
Mar 15, 2007 | Vivitar 283 Flash
Sony Ericsson W200i Cellular Phone Logo
181 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
