Question about Wagner Dual - Temperature Heat Gun
What kind of screw driver do I need to open the casing? All but one of the screws are standard phillips head. The odd one almost looks like a hex screw head with a filled in middle. Anybody know what it is?
  • 518 Answers
Its called tamper proof torx bit. Should be able to get at an autoparts store or Sears.
Posted on Aug 04, 2010
How do I remove the stand to put my LT19C300 Samsung on the wall
Look for holes in the back of the TV just above the stand. There are screws in those holes that hold the stand on. Shine a light in one to see what kind of fastener it uses. Some are phillips head screws, some use hex head screws. Locate the tool necessary to remove the screws and take all of them out. Have someone help you hold the stand while you lift the TV off the stand.
Mar 02, 2015 | Samsung Televison & Video
Graco pack play
Hi Carol, remove the fastener from the opposite side of the one that is missing and take it to a Home Depot or Lowes in your neighborhood. Some well stocked hardware stores may also be able to help. They have both metric and standard threaded screws and bolts and I believe the Graco uses metric. They have boards in the hardware department that should tell you which type you need.
It doesn't usually need to look the same to do the job but if they have nothing to help you out, you will at least know if it's standard (for example 10/24 x 1" which means the screw or bolt is size 10 with 24 threads per inch by 1 inch long) or metric (M5 x 0.8 x 1" which is the metric size closest to a 10/24 x 1") and the type of head, hex or bolt head or a screw driver head, Phillips or flat-bladed.
Armed with that information you'll be able to locate the exact replacement from hardware providers on the internet.
(If the head is unusual, take a picture)
Hope this helps,
The Tinker
Nov 30, 2013 | Baby Gear
What is a t 45 sockett
The T stands for TORX
The 45 is the size
Torx are a type of fastner
Something like a Phillips Head Screw, but a different shape
To work on todays vehicles, you need T 15 thru T 50 Torx
socket drivers & also screw driver handle type torx
Also you need 5mm thru 10mm Metric Hex Drivers also
The torx are for removing lamp housings etc to change the
tail lights,and pretty much anything, not have a metric bolt with a hex head
Jun 03, 2012 | Cars & Trucks
How do you remove chuck?
open the jaws-remove any bit and look down inside-you'll see either a hex or phillips head screw. It will likely be left hand threads so be careful. It should come right off but you might need to lightly pry it off.
Jun 14, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
HELP, Playstaion3 not working.
Hi!
You will need:
-Torx screwdriver
-Phillips head screw driver
-Small flathead screw driver (for removing the rubber foot)
You can also look at the following link for the tutorial of how to open up your PS3.
Disassembly Tutorial
Please rate the solution.
Thanks
Rylee
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
Honeywell fans
There are actually *NOT* 6 phillips screws. There are 4 in an "X" fashion (at 2, 4, 6, and 12 o clock). The last two at 12 and 6 are HEX heads.
The space is *VERY* tight, so you may want to choose a small screwdriver of the correct type, lest you strip the screw completely (like I've just done) and find yourself with a fan-sized hole in your wall.
Also, it may have just been my fan, but if the phillips screws don't come out all the way (like just a little), take a flathead and push *up* from the bottom while you unscrew it. Or you could get lucky and knock them out with a few, well-placed palm strikes.
May 15, 2008 | Honeywell HT-800 Table Fan
Lcd base screws
Went by Future Shop and asked them to show me what kind of screws I needed. The salesperson took one out of a base on display and showed me. I purchased the screws from the hardware store.
Apr 12, 2008 | Televison & Video
Tool to open the heater
what does the screw look like?
Dec 02, 2007 | Honeywell HZ514 Baseboard Heater
Broken on-off switch on Rio 600
They are Hex head screws. You need a small (1.3MM or .050) Hex head bit or Allen wrench. After removing the two screws the case will split. However the problem I'm having is figuring out how to re-attach the switch. It's a very odd connection.
Apr 29, 2007 | Rio 600 MP3 Player
Wagner Dual - Temperature Heat Gun Logo
202 people viewed this question
Top Wagner Tools & Hardware - Others Experts
Craig Butler
Craig Butler
eyecam
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Wagner Tool and Hardware - Other Expert? Answer questions, earn points and help others
